Fuel Pressure Regulator
  • Thread starter Thread starter twinsnakes23
  • Start date Start date May 17, 2010
T
twinsnakes23
23
  • May 17, 2010
Ive got a 90 Mustang GT and I'm going to be adding 24 lbs fuel injectors, a 76mm maf, and a 155 lpm fuel pump. I currently have a 70mm throttle body, cobra intake, edelbrock heads 60cc and stock cam. My question is do I really need an adjustable fuel pressure regualtor or will a stock one be fine? The pressure should be kept at about 39psi anyway right? I would hate to spend $100 on a adjustable on I don't really need. Once I get my car tuned I wouldn't be messing with the fuel pressure. So would I be fine with a stock one? Thanks.
Tanus
847
A to the Z
May 17, 2010
  • May 17, 2010
the stock one will hold it just fine at 40psi, if thats what you want
my plugs always looked lean so I got an adjustable and turned it up to 45psi, basically turning my 24lbs injectors into @26 lbs injectors
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
