  • 1994 - 1995 Specific Tech
FUel Pressure Test Results...
  • Thread starter Thread starter rude_life
  • Start date Start date May 13, 2005
rude_life
372
  • May 13, 2005
Well i did a fuel pressure test today with a mechanic's FP guage.. I tested it with the vaccuum hose on and off, and with the vaccum hose on im sitting at like 20 PSI.. With it disconnected it jumps up to 28-29 PSI..That's pretty low right? WHat type of symptoms can that low of FP cause? Playing with the throttle i could only get it up to 30 PSI max pressure.
PS: I just replaced the factory fuel pump with a new walbro 155 LPH
WhiteDevil
2,717
San Diego
May 13, 2005
  • May 13, 2005
Maybe your regulator then, it should be around 38 with the vacuum off.
mootang
907
texas
May 14, 2005
  • May 14, 2005
that's definatly low!
get an ajustable fuel pressure regulater and see if you can get the fuel pressure up to 38 or 39(at idle with vacume off)
change your fuel filter if you haven't already.
did you loose the power before or after the pump install?
HISSIN50
34
129
May 14, 2005
  • May 14, 2005
agreed. the filter could be restrictive or the FPR is passing too much volume back to the tank. lightly crimping the return line can help to diagnose it further.
good luck.
rude_life
372
  • May 14, 2005
I lost power long before i installed the new pump, and i also replaced the fuel filter. I dont know which one the return line is.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
  • Gulftown980x
  • Jul 29, 2026
squeak93
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
