Fuel Fuel Pressure Video
2011rustang5o
113
View: https://vimeo.com/188061545
Stock fuel pressure regulator. This normal? I was screwing around and unplugged the hose and realized there was zero vacuum. So I ran a new house to a good vacuum source. Before the new house the gauge didn't move at all obviously with no vacuum. This car has been hacked on. The EGR has no vacuum either. Iv tracked every line from the intake to something but none led to the egr, fuel pressure regulator or factory emissions stuff.
I had a slight bucking issue at 1500-1800 and this new vacuum line pretty much cleared that up for the most part. The rest is probably cam.
Sent from my iPhone using Tapatalk
Diagrams courtesy of Tmoss & Stang&2birds
Vacuum diagram 89-93 Mustangs
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
94-95 Mustang wiring diagrams
http://www.veryuseful.com/mustang/tech/engine/#95-95Diagrams
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif tang/tech/engine/images/mustang88VertTopMotorCkt.gif
At the risk of ticking you off, I would highly recommend you remove that rail mount liquid filled fuel gauge, and replace it with a stainless steel line to a gauge or use an isolator with a gauge, or an electric gauge. Why? I have seen too many of them crack or fail causing raw gas to spew all over a hot engine. resulting in fires that have burned a car to the ground.
Reactions: General karthief
Thanks for the heads up. Really no use in it anyways. Just another part to fail.
