Fuel fuel pressure woes...
EX-SSP
81
41
28
New York
So, I have a similar issue to white91 had with his fuel pressure. Pressure is set at 41 psi, vac line off. However, when I throttle the engine, it drops. It doesn't drop as much as others have experienced. It only drops about 5 psi to about 35-36 under throttle. The right back to 41 psi at idle. I have stock fuel rails, 39# injectors and MAF meter. I'm running a 190 lph walboro all feeding a 347 motor. The car drives/runs fine without bogging, at least by the seat of my pants. I'm wondering if it's a case of just needing a bigger fuel pump or might it also be a case of bad/clogged pump or kinked lines? Any thoughts would be appreciated.
That is absolutely fantastic! Well not that the pressure drops but that it is within range. Does the pressure drop because fuel is being distributed throughout the entire system so slightly less pressure/volume of fuel in the lines?
Will getting a bigger fuel pump eliminate that? Does it even matter?
Copied from the FORD RACING PERFORMANCE PARTS catalog:
PROPERLY SIZING FUEL SYSTEM COMPONENTS
Fuel Pumps
The following information is presented assuming the above information has been taken into consideration regarding BSFC, fuel pressure and specific gravity of the fuel being used. Most fuel pumps for electronic fuel injection are rated for flow at 12 volts @ 40 PSI. Most vehicle charging systems operate anywhere from 13.2v to 14.4v. The more voltage you feed a pump, the faster it spins which, obviously, will put out more fuel. Rating a fuel pump at 12 volts then, should offer a fairly conservative fuel flow rating allowing you to safely determine the pump’s ability to supply an adequate amount of fuel for a particular application.
As previously mentioned, engines actually require a certain WEIGHT of fuel, NOT a certain VOLUME of fuel per horsepower. This can offer a bit of confusion since most fuel pumps are rated by volume, and not by weight. To determine the proper fuel pump required, a few mathematical conversions will need to be performed using the following information. There are 3.785 liters in 1 US Gallon. 1 gallon of gasoline (.72 specific gravity @ 65° F) weighs 6.009 LBS.
To be certain that the fuel pump is not run to its very limit, which could potentially be dangerous to the engine, multiply the final output of the fuel pump by 0.9 to determine the capacity of the fuel pump at 90% output. This should offer plenty of ‘cushion’ as to the overall “horsepower capacity” of the fuel pump.
To determine the overall capacity of a fuel pump rated in liters, use the additional following conversions:
(Liters per Hour) / 3.785 = Gallons
Multiply by 6.009 = LBS/HR
Multiply by 0.9 = Capacity at 90%
Divide by BSFC = Horsepower Capacity
So for a 110 LPH fuel pump:
110 / 3.785 = 29.06 Gallons
29.06 x 6.009 = 174.62 LBS/HR
174.62 x 0.9 = 157 LBS/HR @ 90% Capacity
157 / 0.5 = 314 HP safe naturally aspirated “Horsepower Capacity”
Safe “Horsepower Capacity” @ 40 PSI with 12 Volts
60 Liter Pump = 95 LB/HR X .9 = 86 LB/HR, Safe for 170 naturally aspirated Horsepower
88 Liter Pump = 140 LB/HR X .9 = 126 LB/HR, Safe for 250 naturally aspirated Horsepower
110 Liter Pump = 175 LB/HR X .9 = 157 LB/HR, Safe for 315 naturally aspirated Horsepower
155 Liter Pump = 246 LB/HR X .9 = 221 LB/HR, Safe for 440 naturally aspirated Horsepower
190 Liter Pump = 302 LB/HR X .9 = 271 LB/HR, Safe for 540 naturally aspirated Horsepower
255 Liter Pump = 405 LB/HR X .9 = 364 LB/HR, Safe for 700 naturally aspirated Horsepower
Note: For forced induction engines, the above power levels will be reduced because as the pressure required by the pump increases, the flow decreases. In order to do proper fuel pump sizing, a fuel pump map is required, which shows flow rate versus delivery pressure.
That is, a 255 liter per hour pump at 40 PSI may only supply 200 liters per hour at 58 PSI (40 PSI plus 18 lbs of boost). Additionally, if you use a fuel line that is not large enough, this can result in decreased fuel volume due to the pressure drop across the fuel feed line: 255 LPH at the pump may only result in 225 LPH at the fuel rail.
My Comments:
A lot of people oversize the fuel pump by buying a 255LPH pump thinking that the fuel pump regulator will just pass the excess gas back to the tank. It does, but… Did you ever consider that circulating the fuel around as a 255 LPH pump does will cause the gas to pickup engine heat? What happens to hot gasoline? It boils off or pressurizes the fuel tank! With most of the 5.0 Mustangs having the carbon canister removed or disabled, the car stinks like gas, and the gas mileage drops since the hot fuel evaporates away into the air.
Some more on the subject of fuel pressure...
How the fuel pressure regulator works
Revised 5-Jan-2014 to add how to set fuel pressure,
Step 1.) Check fuel pressure:
The local auto parts store may rent or loan a fuel pressure test gauge if you don't have one.
Disconnect the vacuum line from the fuel pressure regulator. Check it for evidence of fuel present in the line by removing it and blowing air through it. If you find fuel, the fuel pressure regulator has failed. Reinstall the line; leave the fuel pressure regulator end of the vacuum line disconnected. Then cap or plug the open end of the vacuum line and stow it out of the way.
Connect the fuel pressure test gauge to the Schrader port located just behind the alternator.
Turn the ignition switch on & start the engine. Observe the pressure: you should see 37-41 PSI at idle.
Turn the ignition off; reconnect the vacuum line to the fuel pressure regulator. Then disconnect the fuel pressure test gauge. Watch out for squirting gas when you do this.
Step 2 .) How the fuel pressure regulator works
The fuel pressure regulator in 5.0 pushrod Mustangs is a shunt regulator that works in parallel with the fuel injection system. The regulator bypasses fuel back to the tank to maintain a constant 39 PSI to the injector tips. A constant pressure insures that the computer will always have the same flow rate to base its calculations on.
The 39 PSI pressure is measured at 29.92 inches of atmospheric pressure to get the proper flow rate. But the pressure inside the intake manifold may be higher or lower than the atmospheric pressure outside the intake manifold. These differences would cause the flow rate to change and mess up the computer’s air/fuel calculations.
As the vacuum inside the intake manifold increases, the effective pressure at the injector tips increases. Conversely, as vacuum inside the manifold decreases, the effective pressure at the injector tip decreases.
Some math to illustrate the effect:
39 PSI at 20” of vacuum inside the manifold works out to be 49 PSI,
since the 20 “ vacuum/2 = 10 PSI that you add to the base fuel pressure.
That gives you 49 PSI at the injector tip.
39 PSI at 5” of vacuum inside the manifold works out to be 41.5 PSI,
Since 5” vacuum/2 = 2.5 PSI that you add to the base fuel pressure
That gives you 41.5 PSI at the injector tip
39 PSI with 10 lbs of boost inside the manifold works out to be 29 PSI.
That gives you 29 PSI at the injector tip
That reduces the flow rate and explains the need for higher pressures on engines with pressurized induction.
Since intake manifold vacuum and pressure plays havoc with the pressure at the injector tips, what has to be done to get it back in the magic 39 PSI range? That’s where vacuum applied to the back side of the fuel pressure regulator comes in. Remember this: unless you have some really poorly designed or trick plumbing, vacuum is the same throughout the engine’s vacuum system.
Apply 20” of vacuum to the back of the regulator and the 49 PSI pump pressure with 20” of vacuum at the injector tips drops to 39 PSI.
Apply 5” of vacuum to the back of the regulator and the 41.5 PSI pump pressure with 5” of vacuum at the injector tips drops to 39 PSI.
Here’s another side effect: apply 10 PSI boost pressure to the back of the regulator and the normal 39 PSI at the injector tips increases to 49 PSI. That overcomes the 10 PSI in the intake manifold to give you 39 PSI at the injector tips. Pretty clever of these engineers to use intake manifold vacuum and pressure that way.
Simply stated, intake manifold vacuum adds to the effective fuel pressure at the injector tips. Apply the same vacuum to the back side of the fuel pressure regulator, and everything balances out. Add pressure to the intake manifold and the effective fuel pressure at the injector tip decreases. Apply the same pressure to the back side of the fuel pressure regulator, and everything balances out.
Now you know why to disconnect the vacuum when making fuel pressure measurements.
I like the FPR explanation, but one thing needs correction. Under vacuum, the fuel pressure output will be lower than 39 psi, and in boost it will be higher than 39 psi. A car under 10psi boost with 29 psi fuel pressure = kaboom. The term is delta fuel pressure, and it means the difference between manifold pressure and fuel pressure. It doesn't matter what the pressures are, as long as the delta is correct. This is why we change fuel filters, because it might flow fine at idle/low rpms, but at WOT/high rpms the clogged line can't flow enough to keep the delta pressure up and leans out the mixture. This is also why it's bad to have a FPR without a vacuum line attached (unless you're testing the fuel system). Tom
Go back and reread the Tech note. It seems that you saw the 29 PSI and the word boost in the same paragraph and quit reading. This is a lot more that you either didn’t read or understand. "The regulator bypasses fuel back to the tank to maintain a constant 39 PSI to the injector tips.... The 39 PSI pressure is measured at 29.92 inches {or 14.7 PSI} of atmospheric pressure to get the proper flow rate. "
The key thing to keep in mind is the term effective pressure
As the pressure inside the intake manifold changes so does the effective fuel pressure at the injector tips. Less than 14.7 PSI in the intake manifold increases the effective fuel pressure. Greater than 14.7 PSI the intake manifold decreases the effective fuel pressure. Now that we know that vacuum or pressure changes the effective pressure at the injector tips, let's proceed onward.
I'm going to introduce a new term PISD. That stands for Pounds per Square Inch Differential. The proper definition is:
"The difference in pressure between two points in a fluid-flow system, measured in pounds per square inch. Abbreviated PSID or psid" (McGraw-Hill Dictionary of Scientific & Technical Terms, 6E, Copyright © 2003 by The McGraw-Hill Companies, Inc.).
The term PSID perfectly describes the situation we have here. In order to preserve the injector flow characteristics, we need to maintain the 39 PSID at the injector tips. That is done by applying pressure or vacuum to the back of the fuel pressure regulator. Pressure applied to the fuel pressure regulator increases the fuel pressure. Vacuum applied to the fuel pressure regulator decreases the fuel pressure. Keep that in mind along with the idea of effective pressure or PSID and you will have a better understanding.
When you connect a pressure gauge to the fuel pressure regulator, you are seeing PSIG. That letter "G" needs some explanation, so I will borrow a very good explanation from https://www.quora.com/Air-Pressure/What-is-the-difference-between-the-units-psi-and-psig
Kim Aaron, Spacecraft Mechanical Engineer writes
When you stick a pressure gage on the valve stem of a tire on a car or a bicycle, the needle is reading the pressure difference between the air inside the tire and the air outside the tire. That's called gage pressure. The units of psig (pounds per square inch, gage) remind us that we are talking about this *difference* in pressure. The absolute air pressure at sea level is about 14.7 psi. Suppose the air pressure in your car tire is 30 psig. Then the absolute pressure inside is 30+14.7 = 44.7 psi. Sometimes, we write that as 44.7 psia (pounds per square inch, absolute) to remind us we are talking about an absolute pressure. In either case, we could just use psi. It just helps avoid confusion to use the psig or psia as appropriate to be clear which we are talking about.
Reactions: EX-SSP
Umm wow. OK, thank you jrichker! Definitely a lot of info there and I truly appreciate all of it. I will have to read through that at least a few times. Good thing it's the weekend. Seriously, thank you!
Fuel Pumps
My Comments:
Why isn't this guy still around lol?
Yeah... He is missed. Dude knew a [lot] of stuff and even the rudest of new members (people that I do not tolerate) mostly rolled right off his back as he tried to help them with their problem.
i'm going to see if the quote thing works. I'm going to quote his above post #4 in my progress thread in reference to my situation.
