fuel pressure?
I am assuming you have an adjustable fuel pressure regulator:)
Set it to stock fuel pressure setting, of 38-40 PSI with the regulator vacuum line (stock is red) plugged with your finger.
Do it while the engine is warm and at idle:nice:
Use the stock pressure for a basic stock engine -38-40 PSI, engine running, vacuum line disconnected from the regulator and capped.
