Fuel Presure droping off??
  • Thread starter Thread starter mustangmarks
  • Start date Start date Apr 21, 2007
M
mustangmarks
102
  • Apr 21, 2007
Hey All,
I'll start with my set up: fuel system
190 FP
BBK Regulator
36LB injectors
Motor is a 306
With TF twisted wedge heads( no work done to them)
10:1 pistons
Performer RPM U/L intake
Paxton SN-92 (8lb)
So at idel I have 45lbs of fuel presure. If I slowly throttle it drops alittle but if I spike it the presure drops to 20 and studers bad. Is there something else I need? I'm open to any sugestions. I'm also taking the presure off the regulator. I tried 2 different gauges.
webslinger67
64
  • Apr 21, 2007
i hate to say it, but it sounds like your regulator is not getting the correct vacuum
G
getusummm
156
  • Apr 21, 2007
Without vaccuum, the pressure would remain the same, not drop. When is the last time you checked your fuel filter? The problem sounds like a volume issue. Dirty filters cant supply enough volume to maintain the pressure. There are other reasons also, but filters are the most common and easiest if everything was working fine before.
M
mustangmarks
102
  • Apr 21, 2007
We are pulling vacum of the plastic fitting that is labaled AC. Is this correct? If not were should I be getting vacum from.
HISSIN50
34
129
Apr 21, 2007
  • Apr 21, 2007
I think Webslinger was indicating that without a strong vac signal to the FPR, there's no FP compensation for greater throttle application. Unfortunately for most cars, the pressure doesnt stay rock solid at 33 PSIG and only go up in a linear fashion, proportionate to diminishing manifold vacuum.
I'm not sure what else is on your vacuum circuit to the FPR, but try running it from a dedicated port (nothing else in a tee or branched from the direct manifold connection). This ensures a strong vac signal to the FPR.
Otherwise, post up if you can make this happen while stationary or if it's only under load. There could be a restriction issue on the way to the front of the car, etc.
Good luck.
G
getusummm
156
  • Apr 21, 2007
More Vaccuum=less pressure
Less Vaccuum=more pressure
If his pressure is dropping off, I really doubt its because he has too much vaccuum.
I would look into fuel delivery issues, especially a clogged fuel filter, or even clogged strainer on the pump.
Has this setup been working properly in the past? Could the pump be too small or going bad?
HISSIN50
34
129
Apr 21, 2007
  • Apr 21, 2007
I think we're saying the same thing. I was concerned with a lack of vacuum reaching the FPR, not too much vacuum.
Because he has a decent pressure differential (but we don't have baseline figures to deduce anything from), this was why I also thought a restriction or volumetric deficiency might be present.
M
mustangmarks
102
  • Apr 21, 2007
I had this similar setup in another car with a 190lph FP with stock heads and a B-cam with no issue. The only change I made was the heads and cam. On my intake I have a fitting in the front that is caped off I will try that. Do you think I need fuel rails that are bigger? Too go from 45 at idel to 18 at 4000RPM is pretty big
M
mustangmarks
102
  • Apr 21, 2007
I also changed the fuel filter and didn't make a difference
M
mustangmarks
102
#10
  • Apr 22, 2007
  • #10
Does anyone have a similar setup?
bentley429
Banned
Nov 25, 2004
528
Connecticut
Apr 22, 2007
#11
  • Apr 22, 2007
  • #11
To me it sounds like your FP is no good, my car used to do basicly the same thing it would go real low when I hammered on it but then it would skyrocket. I replaced my pump with a Holley FI 255 and so far it seems to work great.
M
mustangmarks
102
#12
  • Apr 22, 2007
  • #12
It drops low and dosn't come back til I let off the gas but if I slowly accelerate it stays around 40. Where in CT are you
bentley429
Banned
Nov 25, 2004
528
Connecticut
Apr 22, 2007
#13
  • Apr 22, 2007
  • #13
Northeastern part of the state
C
Fuel pressure help
  • clayton seiders
  • Aug 31, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 1, 2024
clayton seiders
C
  • Locked
For Sale 95 Gt/saleen For Parts Or Project Car
  • from6to8
  • Apr 9, 2016
6K
SN95 Mustangs For Sale (1994-04) Dec 2, 2016
from6to8
N
  • Locked
500+hp 88 LX Hatch, $17k invested, $8500 NJ
  • nighthawk355x
  • Jul 13, 2011
10K
Fox Body Mustangs For Sale (1979-93) May 31, 2012
flatthump
F
Fuel Pressure Drop with Engine Rev
  • AnthonyR23
  • Jul 7, 2009
15K
Fox 5.0 Mustang Tech Jan 23, 2017
Rocky Rodriquez
N
  • Locked
Built blown 88 LX hatch, CHEAP, NJ
  • nighthawk355x
  • Nov 6, 2010
2K
Fox Body Mustangs For Sale (1979-93) Nov 6, 2010
nighthawk355x
N
