fuel problem
  • Thread starter Thread starter handx2
  • Start date Start date Apr 22, 2005
H
handx2
  • Apr 22, 2005
i have an 86 5.0. recently i had a problem getting it to start.the fuel pump didn't turn on when i turned the key.i sprayed in some starting fluid,and it fired right up and was fine for several days.this happened two more times,and then it wouldn,t start at all.i replaced the fuel pump and f.p. relay and still no change.the relay clicks when i turn the key,but the f.p. doesn't engage.i'm running out of ideas here.has anybody else ever experienced this problem.what am i missing?any suggestions would be greatly appreciated.thanks wayne
HISSIN50
34
129
Apr 23, 2005
  • Apr 23, 2005
when it wont prime, probe the terminals in the FP relay socket with a DMM and post what you get.
also run codes if you get a chance. pay attention to secondary fuel codes. good luck.
H
handx2
  • Apr 23, 2005
what is a dmm,and what am i looking for or trying to achieve when i probe the relay .i'm a novice mechanic and i really appreciate your help........wayne
H
handx2
  • Apr 24, 2005
is there a fusible link between the relay and the pump?i checked the inertia switch,and thats not it either.i ran a hot wire from the battery to the pump and drove it today.i,m going to drop it off to a mechanic friend in the morning.where can i find wiring diagrams for my car.thanks........wayne
HISSIN50
34
129
Apr 25, 2005
  • Apr 25, 2005
Wayne, i dont know much about the nuances of your SD 86 vs SD 88's, but on my 88 there is a fusible link for the FP just off the starter solenoid. from the link, the wire goes to the FP relay, connects to the wire from the relay to the pump.
here is a diagram for an 88 (diagram courtesty of TMoss, site courtesy of S&2B's):
did you ever probe the FP relay terminals? that would tell you which way to chase wires. the relay is like a 4 way stop - and knowing what you are missing at what terminal tells you which way to trace.
good luck.
H
handx2
  • Apr 25, 2005
i never got around to probing the relay,mainly because i,m not sure how.i did drop it off to my mechanic today.i hope he can run down the problem.thanks for the link to the veryuseful site.the wiring diagrams will come in handy.thanks ................... wayne
HISSIN50
34
129
Apr 25, 2005
  • Apr 25, 2005
ya should have posted asking for more help - we would have walked you through how to test it out. next time.
good luck with it and let us know what it was.
H
handx2
  • May 6, 2005
i picked my car up from the mechanic and it is running great.i had a broken wire at the relay under the drivers seat.thanks for your help.the link to the wiring diagrams was particularly useful
thanks
wayne
HISSIN50
34
129
May 6, 2005
  • May 6, 2005
thanks Wayne - always nice to see what symptoms equated to what solution.
glad you got it back up and running.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
  • brandyn200
  • Jun 20, 2026
AeroCoupe
