  • 1994 - 1995 Specific Tech
Fuel pump diagram?
  • Thread starter Thread starter stprorolla49
  • Start date Start date Apr 11, 2007
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Apr 11, 2007
  • Apr 11, 2007
Does anyone here have the fuel pump diagram, or the section of the shop manual where it shows how to change one? Instead of paying a **** load of money to get it done at a shop which i never do anyway, my buddy whose done them before said he'd help me. So im gonna get a Walbro 255lph just so i dont have to ever change it again when i do my h/c/i. I'd love a diagram though if possible, thanks.
HISSIN50
34
129
Apr 11, 2007
  • Apr 11, 2007
Michael, does the How-To thread have an article/write-up? I thought it did but I'm too lazy to look.
It's a very academic install - just be careful when working with the retention ring.
Good luck.
95strokerPSU
986
Sacramento from Philly
Apr 11, 2007
  • Apr 11, 2007
It's really pretty straight-foward. If I had a scanner I'd scan my haynes, but to tell you the truth, last time I did the fuel pump, I didn't even use it. There's got to be a write-up either on here or Corral. Good Luck
stprorolla49
1,455
15
39
Apr 11, 2007
  • Apr 11, 2007
Thanks guys, i was on my way out the door, thats why i asked, but im going to look now. If anyone however does have these diagrams, that would be excellent, thanks.
EDIT: So i found a great write-up in the How-To section...
http://www.mustangcentral.net/tech/pumpinstall.html
Thanks fellas!
parchisi
519
New Mexico
Apr 11, 2007
  • Apr 11, 2007
I just followed the instructions that came with it, and its really not too hard. The only hangup I had was trying to figure out the trick to turn that ring so that it disengages...somebody on here told me what to do I think.
m0l0
178
Apr 12, 2007
  • Apr 12, 2007
The only pita on the process was to disengage the fuel connectors ( +11 years of no movement ) and to put the tank back was also kinda tedious
sage2k
645
Baton Rouge, LA
Apr 12, 2007
  • Apr 12, 2007
kit will come with sufficient instructions
2muchtime
890
MA.
Apr 12, 2007
  • Apr 12, 2007
this is easy stuff.. you can do it!!
try doing it with as little gas in the tank as possible...makes a huge difference..
gasoline weighs about 8 pounds per gallon..
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 12, 2007
  • Apr 12, 2007
One piece of advice that I don't know if it's mentioned in the writeup you found (didn't look), but use something brass or wood to turn the retaining ring. One spark and you and the car could be quite crispy.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
