Fuel Pump Fitting
  • Thread starter Thread starter drutt
  • Start date Start date Sep 25, 2004
D
drutt
  • Sep 25, 2004
Hi,
I am fitting a new fuel pump on my 1969 351w Mustang ... i have removed the old one but cannot get the new one in place.... is there a little 'trick' to getting the arm into the correct position?
Cheers
Euge
6Stang7
1,470
Livermore, CA
Sep 25, 2004
  • Sep 25, 2004
Hand crank the engine over a little bit and try again. I guessing that the arm on the pump is hitting the eccentric.
D
drutt
  • Sep 26, 2004
Thanks for the tip... however i am very new to everything car related and learning as i go!!! You guessed it here comes an easy question...
How to I manually crank the engine?
Thanks for all the help
Euge
stangdriva67
60
San Leandro, CA
Sep 26, 2004
  • Sep 26, 2004
answer
You can take a breaker bar and put it on the harmonic balancer bolt and simply turn right until the pump slides in easily and sits properly.
latamud
791
Tampa, FL
Sep 26, 2004
  • Sep 26, 2004
Or you can put the key in the ignition and crank it over just a split second.
Snail50
787
Miami
Sep 26, 2004
  • Sep 26, 2004
If you have a manual trans, can't you put it in a high gear with the key off and roll the car a foot or so?
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 9:30 AM
Ryu
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
