  • 1994 - 1995 Specific Tech
Fuel Pump Fuse Blowing
  • Thread starter Thread starter Yell0wB055
  • Start date Start date Jun 2, 2009
Y
Yell0wB055
  • Jun 2, 2009
Every time I turn the key to the on position the fuel pump fuse in the under dash fuse box blows. I have checked the fuse box, fuel pump, Auto shut off all the way to the steering column. The short is somewhere on the steering column but I can't find it. Do you think it could be the ignition switch ? I don't see anything really apparent like a scorched / skinned wire any where but not sure what to check next. Any ideas would be welcome I am not good at electrical troubleshooting it drives me crazy! lol
Thanks in advance for your help.
HGFireHazard
460
Michigan
Jun 2, 2009
  • Jun 2, 2009
Whenever I think of a fuse blowing every single time I think of continuity. It happened to me on my motorcycle when I wired in HID's and I taped two wires together before individually wrapping them.
Is this something that just started happening randomly or did you do an installation or change something and then it began to happen?
Y
Yell0wB055
  • Jun 4, 2009
I gunned it coming across a bumpy intersection and on A big Down bounce the fuel pump just kicked out
Adam95GT
2,564
Burlington, NJ
Jun 4, 2009
  • Jun 4, 2009
i had a similar problem... start the car and shake the harness on the back pass side.... look for sparks/ popping sounds... turned out to be the connector on my charcoal canister... but i was popping the fuse in the engine bay... also will help to pick up a 20A circuit breaker fuse... much better then buying 50 fuses to try to diag the problem...
http://forums.stangnet.com/709790-car-left-me-stranded-ugh-help.html
Y
Yell0wB055
  • Jun 9, 2009
I can't start the car the fuse blows as soon as I turn on the key but that is a great idea on the circuit breaker fuse I have already been through a box of 20's
Adam95GT
2,564
Burlington, NJ
Jun 12, 2009
  • Jun 12, 2009
Start by shaking a harness then put in a fuze and try to start.... do it over and over again.... till you find it.... good luck.
-Adam
Y
Yell0wB055
  • Jun 18, 2009
Still no action. I have been tugging, shaking and rattling every wire I can find and it blows every time I try to turn it on (Sounds like A cheap **** film description lol) Any other suggestions would be welcome & Thanks so much for the help I have received from here already
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
2003 Mach 1 - F1.28 Fuse blows on KOEO
  • fr500mach
  • Jul 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 19, 2025
fr500mach
F
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
