Fuel pump help
  • Thread starter Thread starter Chetly
  • Start date Start date Aug 1, 2004
C
Chetly
117
  • Aug 1, 2004
i am switching over from a mechanical fuel pump to a electric fuel pump. My new engine block doesnt have the accomodations for the mech one. I have a holley electric, it has an ingoing and an outgoing side. My question is my stock mechanical pump has an ingoing, outgoing, and a return line, i think. What do i do about the return line? Thanks.
HISSIN50
34
129
Aug 1, 2004
  • Aug 1, 2004
how many psi does your new pump flow? i dont have carbed stang experience, but i would probably put a regulator on the inlet line, just to be safe. then i would plug the return line bung. if the new pump flows real close to the stocker, and the stocker had no provision for a return line, i dont see what you would need one now.
cool? bump for ya.
C
Chetly
117
  • Aug 1, 2004
the stocker pump did have provisions for a retrun line. SHould i just get rid of the return line and say screw it. Just run tank to pump, then pump to carb. Thanks.
HISSIN50
34
129
Aug 1, 2004
  • Aug 1, 2004
you could - what i would likely do is get a cheap regulator (they are under 20 bucks, IIRC) and plumb it so you retain the return line.
im sure you could run w/o one - a lot of my carbed stuff does. but a reg is a good idea, IMHO, no matter.
my two cents worth - i bet carbed guys have some nice info for you on this - im just talkin out of my rear.
C
Chetly
117
  • Aug 1, 2004
ttt
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
