Fuel pump install pointers
  • Thread starter Thread starter Stormwalker
  • Start date Start date May 24, 2005
1 of 2 Next Last
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
May 24, 2005
  • May 24, 2005
I did a forum search but did not come up with that great of information.
This weekend I will be swapping out my fuel pump for a 190lph unit. The only other vehicles I have removed gas tanks on are Jeeps. I am thinking this will be a tad different on an 88GT. I am assuming I have to remove the two gas tank straps, and the fuel filler neck. Is there anything else to watch out for? Also, I imagine there is a wire harness for the pump. Is it easy to get at, or did Ford do their usual stupid thing and will I have to drop the tank a few inches because the clip is on top of the tank?
More questions: What else should I be replacing? Does it require a gasket or o-ring of some sort? Also, my fuel gauge does not work the best. The sending unit is located by the pump too, right? If so, it would probably be an opportune time to replace that as well. Thanks for any input and tips/tricks on swapping the fuel pump.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 24, 2005
  • May 24, 2005
To begin a in-tank fuel pump replacement you will want to make sure you have everything you might need to make the install go smoothly and with as little down time as possible. You will want the capabilities of getting the car up and off the ground for ease of install by using either a lift or a couple jacks and jack stands. Get a friend to help you out if possible along with some hand tools. Always be careful when working under a car. The least amount of fuel in the fuel tank makes it much easier so run it low or carefully siphon it out. The Walbro (190lph) pump I got from www.50resto.com came with all the hardware included. This is quoted about the Walbro pieces: “190 & 255 fuel pumps that are marked w/ hardware will include all necessary hardware. 155 fuel pump includes sock only. The 255 fuel pump marked pump only will require the use of a HDW-9350D installation kit.” The hardware has the gasket for between the sending unit base and fuel pump inlet hole, the fuel line clips, crimps, wires, sock, pump, rubber hose and it’s clamps, and lock ring gasket (shown in pic). To go along with the below text here is a Acrobat file off of 50resto’s site that will provide better visualization to go along with the detail.
http://secure.50resto.com/images/downloads/fuel_pump.pdf
First you will want to release the fuel pressure. You can do this with one of 3 ways – 1: You can release the fuel pressure by the schrader valve behind the alternator. It looks like a tire stem valve once the cap is removed. Use a flathead screwdriver to pry in there and release the pressure while using a rag to catch any “built-up” pressure in the system. 2: You can go in your trunk or hatch on the driver side and go underneath the back panel and unplug the inertia switch. Then go ahead and turn the car on until the car dies. You will not be able to crank it up because you burnt the excess fuel off. 3: This is the easiest if time permits because alls you need to do is let your car sit overnight and the fuel pressure will release naturally. Disconnect the negative side of the battery as you will be working with electrically controlled parts.
Jack up the car safely and make sure the jackstands or jack isn’t protruding into the way where you can eventually drop the tank. Get another jack that is handy with a friend to help balance a piece of board to install underneath the fuel tank to help support it. When working under the car with the road dirt and potential fuel spray I think it is a good idea to wear some glasses to keep those things out of your eyes. Get under the car and see that there are two bolts (13mm) that hold on separate straps (2) to pin the fuel tank under the car. Undo the bolts and start to drop the tank a few inches. You will then see different connections into the top of the fuel tank. Just as well you will see the filler neck (where gas is pumped into) coming out of the side of the tank. The filler neck protruedes into the tank quite a few inches so what I did is shift the tank a little to the drivers side carefully to give me more “playing room.” I then began to pull out the filler neck by hand until it was completely out of the tank. There is a very small bolt that holds on a “handle” looking strap that goes over the filler neck which is 8mm in size. Make sure it is undone to move the filler neck where it needs to be. Keep the flexing to a minimum and only do what you need to do to get it out. Now you may lower the fuel tank a little bit more so you can have better access to the sensors/vents in the fuel pump.
Start removing the sensors by pulling up on them and using a broad flathead screwdriver to help you get under the grommets. You can do them by hand as well. Your going to need some A/C-Fuel Line disconnect tools from your local parts store to release the fuel lines off of your fuel pump sending unit (back passenger side of tank). There are two lines: 1: Sending line and 2: the Return line. I believe you can undo one of them with a flathead screwdriver (plastic clip) and the other one you will need to use the proper size fuel line disconnect tool to release it if not both of them. Now that all the grommets/vents/lines are disconnected you can start to lower the tank carefully while being VERY careful to keep any dirt from falling into the tank during the process that could cause premature pump failure. Put some paper towels in the holes to help any falling mistakes that might occur. Pull the tank over on a table or the ground for you to work on. Now is a good time to clean up the tank from any dirty debris all around it. You can also pour out all the gas and take it to a car wash and wash it inside and out and let it air dry for quite a while (depends on your time). I just left the gas in there and was careful about cleaning it and scraping dirt in the tank by accident.
Go ahead and start the fuel pump sending unit removal process by getting a brass punch (or wood) so a spark can’t be created around the fuel tank and it’s gas fumes. Draining and washing the tank will eliminate this problem. You DO NOT want to create a spark. Take the punch and put it against the lock ring and “pop” it counterclockwise to loosen it under the clamps. Remove the lock ring and gasket. Pay special attention to which way the fuel lines are pointing (that you previously disconnected) so you can install it later in the same fashion. You will need to turn the sending unit to remove the assembly out of the tank to reveal the pump/sock/wires. Go ahead and get your new fuel pump ready. Unbolt the two bolts that hold the fuel pump on the sending unit (5mm?). Undo the connection (rubber hose held on by radiator looking clamps) while removing the fuel pump filter (looks like a white sock). I used a screwdriver to pop it off. Cut the red and black wires where you have a enough room to splice into it with the new wires supplied with your new fuel pump (Walbro has them with it). Remove the fuel pump. Use your new rubber hose and match the wires together by color (solder them or crimp them). I just crimped mine nicely with the supplied crimps with the fuel pump. Put in the new pump and sock on it (put it in the SAME direction the previous fuel pump filter/sock was facing) while double checking the connections you just made. You are now ready to reinstall the fuel pump sending unit. It can only properly lay in one way and you can look in the fuel pump to see where it will lie at. Drop it in. Hopefully you were able to pick up a new lock ring and gasket to prevent leaks and have a cleaner install. Go ahead and install them in using the brass or wood punch to install it correctly. While the tank is out check the filler neck grommet (where the filler neck goes into). It will commonly be dry-rotted or rip upon removal of the filler neck. You can get one from your local parts store or at your Ford dealership. Put a thin bit of vaseline on the grommet to help it slide right in. You can do the same with the other vents/grommets.
Put the tank back on the jack/wood and begin to jack the tank back up and once you get some “wire room” start connecting everything back (the connections). Slide the tank a bit to the driver side at a little angle to reinstall the filler neck again being careful not to rip the new grommet you previously installed. Bolt the filler neck handle back on and jack the fuel tank up after you have reinstalled the fuel lines with new clips hopefully if they got broke or damaged. Jack the tank up all the way being carefully to make sure nothing is kinked upon pinning it up. Bolt the strap back up using those 13mm bolts again and remove the jack. It would be a good idea and highly recommended to replace your fuel filter. I run the Motorcraft FG800A or you can get one from your local parts store as well. Alls you need to do is go along the passenger back end of the car and see the fuel lines go in and out of a bracket where a filter lies behind. You can release it by using a flathead screwdriver to break or pop the plastic connections off that hold the fuel lines on it. You can then use the same screwdriver and start unscrewing the surrounding strap to loosen the hold-down bracket on the filter. Pay attention to which way the fuel filter is facing (some aren’t labeled to tell otherwise) so you can put the new one in the right way. You don’t want your fuel filter in backwards. Two new plastic clips should be included with your new fuel filter so you can use them on your fuel lines when you reconnect everything. Go ahead and lower your car back down and reconnect your inertia switch (if need be) and reconnect the battery. Prime your fuel system several times to fill up your fuel system before actually starting. Listen for the fuel pump to prime to make sure it is working properly. Start the car up and check for anything out of the ordinary. You are now good to go!
Good Luck
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
May 24, 2005
  • May 24, 2005
Thank you very much for that comprehensive information. I have printed off your reply, and also the link you gave as well. This will assist me greatly. It looks like I need to purchase some additional supplies as well, since all I have is the pump itself right now, with a couple of plastic clips. Thanks again!
BaXTeR3221
917
Orange County, NY
May 24, 2005
  • May 24, 2005
You should really make that write-up into a sticky, seems like you post it every week or so. It is very good info though
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 24, 2005
  • May 24, 2005
I don't have the power to make that a sticky...but I just paste it when someone ask about a fuel pump install...so how ever often it is asked...that is how often it is answered
SamSnyder
196
  • May 24, 2005
Just 2 things to add: I think you should add an adjustable regulator too; the pressure out of those pumps is slightly different than stock, and you will want to control it accurately. This also means a gauge. I got mine for a good price from MuscleMotors, although they're right in the 'hood (I think around $100 for an Accufab regulator, and $40 for a permanent mount Accugage). The other thing I have to say is a MUST: when you go to release the pump cage from the tank, you need to tap the retaining ring to unlock it -- BE SURE TO USE SOMETHING WOOD OR OTHERWISE NONMETALLIC, SO YOU DON'T STRIKE A SPARK AROUND THAT GAS!!!! Actually, this goes further, and take every precaution to work carefully around the open gas tank. Good luck.
bock
648
Montreal,Qc
May 24, 2005
  • May 24, 2005
i did change my fuel pump last week.Took me 2 hours all alone.
Get a new rubber gasket.
And do this with your batterie disconnect.
also use a wood or brass punch to undo the lock ring.
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
May 24, 2005
  • May 24, 2005
Samsnyder raised another question that I have.
I have an adjustable regulator, but I will probably not be installing that for a couple of weeks, and will do it along with the myriad of other things to do in a h/c/i project.
The weekend between swapping the fuel pump, and doing everything else, there is an autocross I signed up for. Will it matter if I am just using the stock old regulator? Should I hold off on the pump swap or skip autocross?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 24, 2005
  • May 24, 2005
Stormwalker - I had a Kirban AFPR on my car and didn't mess with the fuel pressure after I put in the 190lph fuel pump over my stock 95lph fuel pump...
The fuel pressure was untouched by me and I noticed no ill effects...
89 Saleen#455
519
New England
May 24, 2005
#10
  • May 24, 2005
  • #10
This step-by-step write up might help as well. No pictures, but it covers the whole procedure fairly well.
http://www.corral.net/tech/maintenance/fpinstall.html
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
May 24, 2005
#11
  • May 24, 2005
  • #11
^ Thanks, I printed that out as well. Looks like I will be well armed with information! Hopefully it makes up for competence!
BaXTeR3221
917
Orange County, NY
May 24, 2005
#12
  • May 24, 2005
  • #12
There is also a write up in 5.0 mag, i think it was may of 2003 or 2004. They have some pics that are helpful as well.
Curse
791
El Paso, TX
May 24, 2005
#13
  • May 24, 2005
  • #13
Its a pretty simple procedure, just take your time and if you can get a buddy to help it is than much easier. Let us know how it turns out, good luck.
P.S.
When I installed my 255lph, my FP went up a bit, don't know if it is the same with the 190 just something to think about.
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
May 24, 2005
#14
  • May 24, 2005
  • #14
Hopefully I can talk my girlfriend into helping me work on it again.
Curse
791
El Paso, TX
May 24, 2005
#15
  • May 24, 2005
  • #15
if she does, you know thats a keeper.
SamSnyder
196
#16
  • May 24, 2005
  • #16
The Walbro 190 pump did raise my idle a bit on the stock regulator, leading me to conclude that it was overpowering it a little bit. I picked up about 200 rpm. The idle was also on the soft side -- it did not want to drop back down real quick, so I would say that the pump without a new regulator did affect driveability a little. The Accufab regulator brought that back under control. For street use, I am running pretty near stock fuel pressures.
bmo37
2,368
New Jersey
May 24, 2005
#17
  • May 24, 2005
  • #17
fairly easy install need a jack to support tank, also i suggest a 255lph over a 190lph just cause the 93 and earlier mustangs is a return style system so whatever fuel that isn't used goes back to the tank, why take the chance in installing a 190lphn and for futuer mods it needs more fuel. (all im saying is it can't hurt). just disconnect the fuel level sender and the fuel pump power connector, also buy a new rubber fill hose gasket cause odds are the old one will rip during the removal and install, also to remove the locking wring on the tank i used a flat hear screw driver or a punch and a hammer
Dbeck002
710
South florida
May 24, 2005
#18
  • May 24, 2005
  • #18
190s can support as much power as the block can handle. I think youll be ok, but yea I am getting a 255 just because I want to get it out of the way. 190 is still good though bro.
BaXTeR3221
917
Orange County, NY
May 24, 2005
#19
  • May 24, 2005
  • #19
Ditto.
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
May 24, 2005
#20
  • May 24, 2005
  • #20
Sam, you rpm difference was most likely because at idle voltage the old pump wasn't creating enough pressure.
One other tip is to lube the fuel tank grommet and fuel lines with some white lithium grease before reassembly, good for the rubber and most likely they wont tear regardless of how difficult the tank acts.
Also once dropped I usually jump the fuel pump relay and pump the fuel into a 5 gallon can just so it's lighter during reassembly. Tilting the tank to pour it out usually fill the jug up with sand and dust too. PITA.
If the locking ring is rusty spray it down and walk away for a while. Pretty miserable once you knock all the tabs off the ring (experience speaking)
Jamie
1 of 2 Next Last
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
