  • 1994 - 1995 Specific Tech
fuel pump installation
  • Thread starter Thread starter jtb19nh
  • Start date Start date Feb 9, 2006
jtb19nh
156
Feb 9, 2006
  • Feb 9, 2006
Just got my 255 lph fuel pump. Any advice to make the job go smoothly?
95strokerPSU
986
Sacramento from Philly
Feb 9, 2006
  • Feb 9, 2006
Just make sure you have someone to help you lower the tank and make sure you put the new pump in the same exact way the old one came out. Pay special attention to how the filter bag thing is suppose to be.
Good luck
fluffyrunnells
new hampshire
Feb 9, 2006
  • Feb 9, 2006
dont worry i'll be there to help..........meatball
MysticKeith50
330
Pennsville, New Jersey
Feb 9, 2006
  • Feb 9, 2006
when u do it, it is always nice to make sure there is as little gas in the tank as possible.....make the tank a little easier to handle!
HISSIN50
34
129
Feb 9, 2006
  • Feb 9, 2006
In the how-to sticky, David (5spd GT) did a nice write-up on what is involved, parts needed (with part numbers, etc). I would check it out.
Good luck.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Feb 9, 2006
  • Feb 9, 2006
On the filler neck there is a 8 or 10 mm bolt remove it before trying to wiggle the tank lose. Here how I did mine:
1.Jack the car up and placed two jach stands on the diff.
2.Then placed the jack under the tank
3.remove the bolts on the straps holding the tank.
4.remove the 8/10mm bolt from filler neck.
5.lower the jack slowly to gain access to the fuel lined.
6.disconect the fuel lines and connectors.
7.lower the tank completely.
8.using a brass punch or screw driver if you don't have one **brass will not cause sparks so be carefull using anything else** remove the lid holding the fuel pump.*it must be twisted off to remove and twisted back on to tighten, you'll see what I mean it you haven't done it before*
9.remove the fuel pump.....have patients to will more then likely be PITA to remove it only comes out one way and install one way....have patients.
10.install by going backwards good luck...
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
Fox Prepping a '91 to start after 5 years sitting?
  • 331strokerGT
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2026
limp
