  • SN95 4.6L Mustang Tech
fuel pump pressure?
  • Thread starter Thread starter darkside03gt
  • Start date Start date Jun 18, 2008
D
darkside03gt
851
Sacramento CA
Jun 18, 2008
  • Jun 18, 2008
I am currently trying to get my supercharger tune dialed in and my tuner noticed that my fuel pressure is up above 60 at times. its a single focus pump with no other modifications. anyone know wtf it could be? because i sure a hell dont I thought it was normal with this pump.
the98stang
2,408
Clovis, CA
Jun 19, 2008
  • Jun 19, 2008
Seems normal to me. Way better than not having enough fuel pressure that's for sure...
NO BRAKES
129
Avon Lake, Ohio
Jun 19, 2008
  • Jun 19, 2008
what fpr are you running? and are you seeing this 60lbs of pressure under boost or regular driving?
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 19, 2008
  • Jun 19, 2008
sounds right to me too.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jun 20, 2008
  • Jun 20, 2008
his pressure is over 60 at idle
D
darkside03gt
851
Sacramento CA
Jun 20, 2008
  • Jun 20, 2008
its not right. over 60 at idle is wrong.
bhuff30
6,037
35
129
Olathe KS
Jun 20, 2008
  • Jun 20, 2008
The FPR should be able to keep the fuel pressure down. I'd guess either the fuel pressure regulator isn't working or there is a restriction in the fuel return line (or the return is just plain too small).
At idle, you should get 30-34psi
At WOT with no boost, 40psi
At 10psi boost, 50psi
At 20psi boost, 60psi
See the trend?
D
darkside03gt
851
Sacramento CA
Jun 20, 2008
  • Jun 20, 2008
See the trend?
this is a returnless system.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 21, 2008
  • Jun 21, 2008
he didnt say it was 60 at idle. if it is at 60psi at idle there is a problem
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 21, 2008
#10
  • Jun 21, 2008
  • #10
has the car been tuned??
after my PPRV delete my FP was jumping like crazy!! after the tune it was smooth again
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Jun 22, 2008
#11
  • Jun 22, 2008
  • #11
your tuner needs to adjust the voltages for the new pump in the tune. if he doesn't the adaptive learning may correct it. if he is using SCT stuff to tune the car, he should have the file needed to run the focus pump.
D
darkside03gt
851
Sacramento CA
Jun 22, 2008
#12
  • Jun 22, 2008
  • #12
I took care of it. thanks guys.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 22, 2008
#13
  • Jun 22, 2008
  • #13
so what was it??
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
