Fuel pump problems?
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Well I've been having some little bugs with the 5.0. When I go to start the car, if it's cold it takes a very long cranking session before it actually starts. I was wondering what this could be, I would say the fuel pump. I also seem to get HORRIBLE gas mileage. Somewhere in the 13-14 range.
Could these problems be related? What are the first steps I should take to test it?
I would put a fuel pressure testing gauge on the Schrader valve and note the pressure before you try to start it, and watch as pressure builds during cranking.
Alternatively, you can turn the key to run and let the pump prime a couple times before trying to actually start the car for the first time. If it catches immediately this way, that suggests a pump or FPR, and the latter can be ruled out with further testing.
I wouldnt look at bad fuel economy and a weak pump as being related necessarily.
Good luck.
fuel pump problem
let me tell you a fuel pump story when i was new to 5.0's . i drove pretty much stock 5.0 as daily driver about 20 miles to work each way about 10 miles or so into ride car would buck surge and hesitate. more i mashed gas more nothing would happen. so i thought let me change fuel filter same thing would happen . so i buy fuel pump go to put it in i see fuel pump sock full of hair at least thats what it looked like. so what happened was car would start and drive fine but as fuel picked up it sucked hair into bottom of fuel pump screen and essentially clog fuel pump after sitting few hours it would settle back into fuel sock and process would start all over again when i drove car. just figured i would add little story never know what might be going on when it comes to our beloved 5.0's
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
