  • SN95 4.6L Mustang Tech
Fuel Pump Problems ???
  • Thread starter Thread starter shonoff
  • Start date Start date Nov 17, 2006
shonoff
105
Ohio
Nov 17, 2006
  • Nov 17, 2006
My 99 GT has gave me problems a couple times this week not wanting to start. It will start, and sputter a couple times and then die. After switching the key on and off, sometimes a dozen times, it will start and run fine...................I kept checking the fuel pressure today by turning the key on, then I would relieve the pressure and check again later. A couple times I was getting 10 psi. A couple times it read 30 psi, and after that I was getting 40 psi everytime. So I am thinking my pump maybe on its way out, but Id like to hear some input from others who know more than I before I spend $200.00 on a pump............Thanks
M
mr-mike
122
  • Nov 17, 2006
did you change the filter ? they say 30 lbs is fine , unless the sock in the tank is clogged I would change the filter first
shonoff
105
Ohio
Nov 17, 2006
  • Nov 17, 2006
Yep. changed filter Monday..................problems started tuesday. It may or may not be a coincidence
BooWFO
991
Louisville, KY
Nov 17, 2006
  • Nov 17, 2006
Ok so you changed the filter then the problem occurred?? Double check your install.
Also 200 bucks for a pump is nuts it's a 99 right? returnless fuel system? If so just get a svt focus pump they are usually right at 100 bucks and flow alot more fuel than the stock one if you do in fact need a new fuel pump.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 17, 2006
  • Nov 17, 2006
Is it a MOTORCRAFT fuel filter? Is it installed backwards?
shonoff
105
Ohio
Nov 17, 2006
  • Nov 17, 2006
its a motorcraft installed correctly.
M
mr-mike
122
  • Nov 17, 2006
bought a new fuel filter some years back as always I blew thru it ..coudnt ? went back & the guy in the store said the skells bring back dirty filters & say they picked up the wrong one ? honest he said it became such a problem they started opening returned items & caught 5 guys in one week after that the word got out & it seemed to slow up but it didnt stop ...so you never know .....
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
