Fuel pump taking a dump? searched
mob
the guy who hits on his mom
Oct 3, 2003
2,566
136
104
Dallas, TX
Well i know when you have an aftermarket fuel pump it tends to be pretty loud, but considering my car was a bucket when i bought, still had the air silencer and was owned by mexicans (no offense) i seriously doubt they put an aftermarket fuel pump in it. I have a o/r hpipe, 2 chamber flows, and a bcam, and with my windows up, i can hear my fuel pump over all of them, and its freaking LOUD, pretty annoying. Someone told me to check ill have to take out the tank and stuff, and he also said they usually whine when there about to take a dump, should i have it checked out?
I also have another question, if anyone wants to take a shot at it. I took my car to a shop to do some things, and the guy told me that the driveshaft didnt want to turn, and it wasent the rear end it was the brakes. When i got my car out of the storage for a few months about 2 months ago the brake light was on and the brake fluid resivous was empty so i put some in to the top, now about 2 months later the light came back on and it was about half full and the light turned off when i put more in. Do i probably have a leak? Could that have something to do with the driveshaft not turning? The shop said to take it back to them to have all the brakes checked out. and my handbrake dosent work AT ALL unless i put pull the handle till its vertical, literally, is that just adjusting or something? And also when a bit back when i was in like 5th gear at like 60mph if i let off the gas the car started jumping foward like crazy like the ujoints were bad, i think thats what it was but it dosent really do it anymore, im about to have gears instaled, should i change the ujoints and balance the driveshaft at the same time? thanks guys
Nick, oh boy. Pumps do tend to whine more in my experience when they are on last legs or when fuel level is low. If you have doubts and are going to keep the car, I would swap it out for a new, larger pump. Then forget about it.
If you take the drums off, does the DS turn easier? AIr in the system can keep caliper pistons and wheel cylinders from retracting (they rely on a hydraulic seal in the system. When the pedal is not pushed down, the hydraulics create a bit of a vacuum to retract the pistons/cylinders.
I would search really hard for the leak. Rear wheel cylinders are always likely. You might have to pull the drums to see if the cylinders are wet.
The ebrake might have a broken mounting bracket near the trans. One can adjust the ebrake slack via the star wheels on the drums.
I would really recommend not driving it till you know what is going on.
Good luck bud.
NOT DRIVING?! haha dude, i drive my car like 30+ miles a day, its my daily driver, only ride to school and work, i have to drive it even if i have no brakes. Thanks for the indo though, im broke but ill have it checked out soon, atleast i have an idea of whats going on
Nick,
Also check the hose in the center of the rear end for leaks. They tend to leak where it connects to the body.
I would also spend a few dollars on a pump now as well. It could save you from getting stranded somewhere.
And when you change out the fuel pump, it is a good idea to change the rubber grommet for the filler neck and replace the fuel filter while you are right there. Clogged fuel filters can lead to pumps straining cause them to burn out.
thanks guys, after the gears go in ill get a new fuel pump, what do you guys suggest 155? 190? Im looking at maximum motorsports i dont know why but i like them alot
Since it is a few bucks more, the 190 should be fine (though the 155 is likely more than enough unless I missed something in your sig). Kevin might feel differently.
I would go with a Walbro pump, which can likely be sourced cheaper (new on ebay, online speed/resto shops, etc). I have not priced MM stuff though.
Wise advice from Kevin on the grommet and filter. Grommet is about 20 bucks (dealer or online only, for me).
Good luck.
Good luck.
I feel about the same as JT on this one but I will add on it for you.
I would say the 190 is a good choice. Thats the pump I ran in my car and it worked just fine. But then again I didn't buy it, a friend gave it to me. :D
If you wanted to get the 255 it would be fine as well and would not hurt anything and is only a few dollars more than the 190.
It really all depends on your goal with the car. If you plan on a lot more changes for HP then the 255 for a few more $ would be the way I would go, if not then save the few $ and go with the 190 and use the extra $ for the grommet and filter or save a few more and go with the 155.
I hope I am not confusing you. :crazy:
Just trying to help you keep from pulling the fuel tank out again "if" you need to upgrade later on down the road.
