  • SN95 4.6L Mustang Tech
Fuel Pump Test?
  • Thread starter Thread starter Jacob_Royer
  • Start date Start date Mar 23, 2010
Jacob_Royer
142
  • Mar 23, 2010
I filled my car up today and afterwords it wouldnt start! i noticed when i started it earlier it cranked for longer than usual. Anyway i have no fuel at the rail as i have pressed down the shrader valve with the key on and didnt get any gas. No codes are showing (i have an OBDII reader) and i cant here the pump in the tank. banged on the tank and couldnt get it to kick the pump on. Anyway im wondering how to test the pump? I noticed when i turn the key on i here some clicking from a box in the passenger side fenderwell no idea what it is or why i here clicks? just had a fender put on that side so i wonder if they could have messed somthing up there? but i do know it has cranked for longer than it should for quite some time! also it has 230k miles or so on the original pump! Like i said i need to know how to test it and where the relay is located (i have no owners manual and box isnt labeled!) Also any tricks to dropping tank? its unfortunately full of gas!! do i have to drop the exhaust? also parts store claims there are two pumps one with a brass inlet and one with plastic? which one should it be? (96 gt) sorry for all the questions i just had a horrible day and finaly got the car back home (80 *@(&# miles from home and on my way to night school when it screwed up!)
Thanks for any help it would be much appreceated!!
beerman1378
28
  • Mar 23, 2010
The clicking under the pass side firewall would be ur Constant Control Module. This covers various electrical and ur fuel pump. Mine just went and I am putting a new on in tomorrow morning. Im by far no expert on this subject but I figured Id throw my .02 in
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Mar 23, 2010
  • Mar 23, 2010
The CCRM is located in the passenger's fender well. The clicking sound is most likely coming from the CCRM.
Start first by checking the battery. All ALL terminals clean and tight? Is the battery fully charged?
Next, check all of the fuses. There are two fuse panels.
If recent work on the passenger fender, IMO, a good possibility that has damaged the CCRM. However, just to be sure, check all of the fuses.
Jacob_Royer
142
  • Mar 24, 2010
It turned out to be the pump i probed the hot running to it and it had power, $108 for a pump $10 for a strainer (orielly) and im back on the road! I now have a handy stainless removable access panel under my trunk carpet so fuel pump swaps are easy! why the hell didnt for do that in the first place? oh thats right they wanted us to have them fix it!
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
