fuel pump wiring
  • Thread starter Thread starter 68_stanger
  • Start date Start date Apr 26, 2006
68_stanger
131
Petoskey, MI
Apr 26, 2006
  • Apr 26, 2006
I'm using a electric fuel pump in my 68 and its works well however I would like to change one thing about it. The pump is wired through a oil pressure switch and won't start to pump until oil pressure builds. Iwould like to set it up so that when I turn the key it runs for a few seconds to "prime" the system then shut off, like modern vechicles. How would I go about this? Thanks
iskwezm
4,159
20
79
Rowland Heights,California
Apr 26, 2006
  • Apr 26, 2006
I just have mine wired on a switch and powered by the key
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Apr 26, 2006
  • Apr 26, 2006
Run a wire from the "S" terminal of your starter solenoid through a diode to your fuel pump relay.
This will make the fuel pump act the same as normal except it'll also run while you are cranking the engine. You need the diode because you only want current to flow 1 direction..otherwise your fuel pump relay would be trying to power your starter solenoid while the engine is running.
brianj5600
1,964
Middle TN
Apr 26, 2006
  • Apr 26, 2006
I llike a toggle switch that is always hot. That way I can get gas to the bowls easily and since it is not in plain sight, it is a form of theft deterent.
J
Having fuel issues
  • Jbands2v
  • Monday at 2:56 PM
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Monday at 4:39 PM
LILCBRA
  • Mindseye007
  • Aug 16, 2026
Mindseye007
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
