  • 2.3L (N/A & Turbo) Tech
fuel pump
  • Thread starter Thread starter SVOconvLX85
  • Start date Start date Nov 1, 2004
SVOconvLX85
251
Vegas, for a while...
Nov 1, 2004
  • Nov 1, 2004
Does anyone think that a stock 5.0 fuel pump will supply my turbo motor with 12 lbs. of boost?
mr_woodster
1,314
Riverside, CA
Nov 1, 2004
  • Nov 1, 2004
Save yourself the trouble and put in a 255lph now, you dont want go back there again later to do it right. Yes a 5.0 pump *should* have enough flow on a stock motor for 10-12 psi, that is *should*. But why would u even want a turbo motor that only runs 12 psi...that is slower than stock
Bearded Forever
Type O Danzigative the Dark
4,927
Vinland
Nov 1, 2004
  • Nov 1, 2004
That 5.0 fuel pump is an an 88lph pump,
same as the all Turbo Fords.
351wcoupe
1,811
Manhattan, Kansas
Nov 2, 2004
  • Nov 2, 2004
yep. They were the same.
So if you need to practice pulling the tank or you suffer from insomnia go ahead and switch them.
SVOconvLX85
251
Nov 3, 2004
  • Nov 3, 2004
Its already in becauyse I neede3d a quick fix for my bad external. I didn't have enough time to order a 255 because the car was already apart, but it will be bought in the near future. You said they were 88lph but the side of the pump said only 60 lph. I know the car had some modifications done to it so I know the 5.0 was getting enough fuel for its needs, but why is it only 60 lph?
kiddiccarus
The first widely accepted Tranny
20+ Year Stangneter
Dec 24, 2003
1,789
1,051
143
30 Mins from a Ragged GT
Nov 4, 2004
  • Nov 4, 2004
Hey, can I toss in the 255 now on the N/A motor and it work like the one in the tank now does? Or will I have to wait for the swap to do this?
kiddiccarus
20+ Year Stangneter
Dec 24, 2003
1,789
1,051
143
Nov 6, 2004
  • Nov 6, 2004
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
N
89 LX 5.0 Fuel Rail Recommendations
  • Ncarter
  • Oct 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 18, 2025
rednotch
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
