Fox 88 foxbody no power to red and black wire at fuel pump relay
drod88
Winter haven fl
I have a 88 5.0. Since I bought it the fuel pump never held pressure. It has a permanent fuel pressure guage on the header panel. Recently the pump stopped priming all together. I figured it finally gave out so I dropped the tank. I noticed my gas tank sub harness was in rough shape so I replaced the pump and the harness. Now the pump still doesn't prime. I replaced the fuel pump relay still nothing. If I pull the relay out little bit the pump runs constantly even with the key off. With the key on I have no voltage to the red and black signal wire. If I apply 12v to the red and black wire the pump primes.
Literally discussing this on another thread here:
Have you checked for codes yet?
Reactions: Shakerhood
I have not pulled codes i will do that today. I forgot to mention the eec relay was corroded on 1 of the pins I swapped the relay with a universal and still nothing. And I have no power at all to the inertia switch.
There are wiring diagrams in that thread I linked with some good trouble shooting info. If you cannot pull codes its a pretty strong indicator you need to get the ECU fixed. Most of us are using this place:
Not saying that is it but it very well could be. Run through that thread I linked.
Reactions: drod88
I got it running! Apparently the eec relay and the inertia switch went bad simultaneously. I bypassed the inertia switch and replaced the eec relay and shes running. Codes indicate a cylinder 6 misfire. It runs really smooth but does seem underpowered. I've recently replaced the distributor, cap and rotor, plug wires, plugs, fuel pump walboro 255, bbk headers and h pipe, new coil. It runs too smooth for the cylinder to be dead im at a loss with this one. I had timing at 10° i bumped it up to 12 and then 14 still seems underpowered.
