fuel pump
  • Thread starter Thread starter NFGTragedy
  • Start date Start date Apr 28, 2005
N
NFGTragedy
155
Rochester, NY
Apr 28, 2005
  • Apr 28, 2005
I did a 4cyl conversation to 5.0 and i tried to start the motor today... everything went great except for the fact that my fuel pump doesn't want to kick on. I have a fuel tank out of a 5.0 mustang. I have a 89 mustang and the fuel pump relay is under the drivers seat. Is it the same for 4cyl and 5.0? What else could be causing it not the want to go on?... Thanks
95opal
5 Year Member
Nov 16, 2004
449
20
39
Apr 28, 2005
  • Apr 28, 2005
first of verify if the pump is getting power if it is then obviously the pump is bad.if no power then start backwards from their.
N
NFGTragedy
155
Rochester, NY
Apr 28, 2005
  • Apr 28, 2005
How would I go about doing that?
seijirou
2,417
DFW
Apr 28, 2005
  • Apr 28, 2005
Also check the inertia switch.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 28, 2005
  • Apr 28, 2005
Fuel Pump Troubleshooting for 87-90 Mustangs
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power path.
The control path consists of the inertia switch, the computer, and the fuel pump relay coil. It turns the fuel pump relay on or off under computer control. The switched power (red wire) from the ECC relay goes to the inertia switch (red/black wire) then from the inertia switch to the relay coil and then from the relay coil to the computer (tan/ Lt green wire). The computer provides the ground path to complete the circuit. This ground causes the relay coil to energize and close the contacts for the power path. Keep in mind that you can have voltage to all the right places, but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump relay contacts. When the contacts close because the relay energizes, the power flows through the contacts to the fuel pump (light pink/black wire). The fuel pump has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays or injectors, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/t...witchWiring.gif
http://www.veryuseful.com/mustang/t...inks-ign-ac.gif
http://www.veryuseful.com/mustang/t...91eecPinout.gif
Now that you have the theory of how it works, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay). No voltage or low voltage, bad fuse link, bad wiring, bad ignition switch or ignition switch wiring or connections. There is a mystery connector somewhere under the driver’s side kick panel, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously described. Look for 12 volts at the Light Pink/Black wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed, or there is a broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the Red wire and Red/Black wire. Power on the Red wire and not on the Red/Black wire means the inertia switch is open.
The Tan/Lt Green wire provides a ground path for the relay power. With the test connector jumpered to ground, there should be less than .75 volts. Use a test lamp with one side connected to battery power and the other side to the Tan/Lt Green wire. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the wiring between the computer and the fuel pump relay is bad.
If all of the checks have worked OK to this point, then the computer is bad. The computers are very reliable and not prone to failure unless there has been significant electrical trauma to the car. Things like lightning strikes and putting the battery in backwards or connecting jumper cables backwards are about the only thing that kills the computer.
Black 93 Fox
1,995
Vancouver,Washington
Apr 28, 2005
  • Apr 28, 2005
How long did it take you to type all that.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 28, 2005
  • Apr 28, 2005
About 30 seconds.
It is small part of a 37 MB + Mustang tech library that I created on my computers. I do the write ups, debug the processes, and save them. Then I cut & paste them into posts when someone has a question that I can give a quality answer for.
seijirou
2,417
DFW
Apr 28, 2005
  • Apr 28, 2005
You know, you could probably sell that tech library of yours.
StreetDreamsGT
449
New Jersey
Apr 28, 2005
  • Apr 28, 2005
you know, i'd probably buy that library of yours
MrKwik
1,008
Kansas City, Kansas
Apr 28, 2005
#10
  • Apr 28, 2005
  • #10
You didnt say if your car is injected or carbed so I dont know if I can help but I have 2 V8 cars that started life as 4 bangers and this is what I did...
Note that both my converted cars are carburated so if yours is injected this probably doesnt apply one little bit. Although I suppose this would work on an injected car (with the exception of the oil switch since the pump doesnt run till the motor fires) I dont know if there is a better way since I have never done a V8 conversion to EFI.
The 4cyl car had that relay box under the hood and the fuel pump relay was in there, not under the seat like a 5.0 car. What I did was to mount a relay where the ECU used to be in the passenger side kick. You will find a dk grn/yellow wire in one of the square connectors there. I believe it was a green connector but could be gray, dont remember for sure. That wire goes to the inertia switch in the trunk. I ran a 10 or 12ga wire from the solenoid to pin 30 on the relay and hooked the dk grn/yellow wire to pin 87. Then I hooked the lt blu/yellow wire in the same connector to pin 85. Thats wire is hot in run. Pin 86 goes to an oil pressure switch that grounds when there is pressure but you could just ground pin 85 if you want the pump to run whenever the ign is on. I wante it to stop if the engine dies or otherwise loses oil pressure so I wired in the switch.
I used holly red pumps mounted between the trunk and bumper and wired them to the original EFI pump wires so that the inertia switch is still functional.
N
NFGTragedy
155
Rochester, NY
May 2, 2005
#11
  • May 2, 2005
  • #11
Mine is EFI.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
May 2, 2005
#12
  • May 2, 2005
  • #12
jrichker said:
About 30 seconds.
He's a GREAT resource on the boards.....
(Mine is 35MB)
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
  • Mindseye007
  • Aug 16, 2026
Mindseye007
