fuel pump
  • Thread starter Thread starter load71
  • Start date Start date Aug 23, 2005
load71
68
  • Aug 23, 2005
As of right now i have a 155 fuel pump in my car. Since the accident i am in the process of swapping everything over to shell. I am going to be doing a 331 stroker with trick heads, custom cam? and intake. I was wondering what size injectors, and do i need a bigger fuel pump, or can i kept the 155? Also what size meter should i get, i want to go with pro M! Thanks guys
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 23, 2005
  • Aug 23, 2005
A 155 LPH pump will work good with 24 Lb injectors.
load71
68
  • Aug 23, 2005
So i should go with the 24's? Not 30's?
load71
68
  • Aug 24, 2005
any one eles?
$uperstang
476
Detroit, MI
Aug 24, 2005
  • Aug 24, 2005
Take it from me 24's are fine!
load71
68
  • Aug 25, 2005
What size meter? Pro M 77 would be fine to?
$uperstang
476
Detroit, MI
Aug 25, 2005
  • Aug 25, 2005
What size Throttle body are you going to use?
load71
68
  • Aug 25, 2005
accufab 70MM
vristang
4,933
101
124
Seattle
Aug 25, 2005
  • Aug 25, 2005
Injector and pump size are dependant upon hp levels. Let me know what power level you will be at and I can run the numbers for the injectors. Here is the info on fuel pumps...
Ford EFI Options____N/A 80%________Boost 80%
110_________________240hp__________200hp
155_________________340____________280
190_________________420____________340
255_________________560 ___________460
Running the pump at 80% of its full capacity keeps the pump from overheating, which extends its life, and provides a margin of safety for max output runs. Same applies to injectors.
By the way these are flywheel numbers, not rwhp.
stroked86
25
ct
Aug 25, 2005
#10
  • Aug 25, 2005
  • #10
I would go with 30's or 36's they say 24's are good for 350 or so but there is no room plus you'll be running the injector to hard you want to be around 85% duty cycle for an injector... you can make it with 24's but if your buying them anyway I would run one of the other two and go with a 80mm mass air as for the pump it might work but you will probably run out of that on the top end also with a 155 I would just get the 255 and be done with it.....
Daniel50
716
Discovery Bay, CA
Aug 25, 2005
#11
  • Aug 25, 2005
  • #11
buy a 255lph and be done with it. will support your fuel system for anything just about you do and all the extra fuel is sent back to the tank
vikingpower
656
CWU Ellensburg, WA
Aug 25, 2005
#12
  • Aug 25, 2005
  • #12
I've had a 255 pump for about a year now, no probs so far with my mild setup... it did burn up some of the factory wiring though so I replaced with an inline 12amp fuse and 12 guage wire I think
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
