Fuel pump
  • Thread starter Thread starter sidl3000
  • Start date Start date Nov 25, 2005
sidl3000
27
  • Nov 25, 2005
ok so yesterday I drove 5 hours back to school. No problems. I wake up go to start my car and it just cranks and cranks, then I realize the fuel pump is not priming. Bad fuel pump or relays? I have never had this problem and to my knowledge the fuel pump or the relays have ever been changed. btw I have a 1988 GT
J
JB66
565
New York
Nov 25, 2005
  • Nov 25, 2005
Try this post.
http://forums.stangnet.com/showthread.php?t=595862&highlight=fuel+pump
T
TooFoxy
58
Charleston SC
Nov 25, 2005
  • Nov 25, 2005
i had same problem for a while about a year ago come to find out the ground for my computer had worked its self alittle lose... the one that is right next to the computer.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 26, 2005
  • Nov 26, 2005
The ground you fixed was the shield for the TFI wiring and the computer case. The real computer power ground is out by the starter solenoid.
The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
D
1989 mustang 5.0 crank no start
  • Darkstang302
  • Nov 10, 2026
Fox 5.0 Mustang Tech Sunday at 8:36 PM
AeroCoupe
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
  • Mindseye007
  • Aug 16, 2026
Mindseye007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
