Fuel Pump
  • Thread starter Thread starter chr1s11575stang
  • Start date Start date Oct 17, 2007
chr1s11575stang
64
Orlando, Fl
Oct 17, 2007
  • Oct 17, 2007
Ok I read all the threads but didnt see this question. When Im ruuning the car as long as my foot is on the gas the engine light stays off. but the second i let off the engine light comes on. It starts fine and everything and you can hear the fuel pump priming. When I turn off the car it sounds like the fuel pump keeps running for like 1-3 mins after wards. What could this be?
baldy1
124
Portsmouth Va
Oct 17, 2007
  • Oct 17, 2007
Pull codes first. Then we can go on from there
corvetteguy
71
  • Oct 18, 2007
If the pump regularlly runs that long
after each turn off. I would
locate the relay and be ready to
pull it out of the socket when it is
running on.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 18, 2007
  • Oct 18, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
chr1s11575stang
64
Orlando, Fl
Oct 19, 2007
  • Oct 19, 2007
ok thanks. i ordered the code reader so as soon as i get i will let you know what the codes are. thanks for the help
  • Mindseye007
  • Aug 16, 2026
Mindseye007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
  • brandyn200
  • Jun 20, 2026
AeroCoupe
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
