  • 1994 - 1995 Specific Tech
fuel regulator?
  • Thread starter Thread starter SaltWaterFish
  • Start date Start date Mar 27, 2004
SaltWaterFish
208
Cedar Rapids, IA
Mar 27, 2004
  • Mar 27, 2004
I installed a Kirban regulator and a Summit fuel gauge today and need to know if you set the pressure with the vacume line on or off? Is 38psi a good start?
C
CivicEater
579
  • Mar 27, 2004
hey what is the part number off your guage.....fit alright?
Slow5.0
2,554
Portland, OR
Mar 27, 2004
  • Mar 27, 2004
38-40I say , but I run 42
Rel
344
Los Angeles, California
Mar 27, 2004
  • Mar 27, 2004
Set it with the vacuum line OFF - I'd say 39-41
I think stock is 39?
Slow5.0
2,554
Portland, OR
Mar 27, 2004
  • Mar 27, 2004
If he set with vac line off 39-41 than when he connect line pressure gona drop about 2psi so that gonna be 37-39
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Mar 27, 2004
  • Mar 27, 2004
What he said. My FP was 38psi with vac. line hooked up, 40psi without it
SaltWaterFish
208
Cedar Rapids, IA
Mar 28, 2004
  • Mar 28, 2004
The p/n for the gauge is SUM-800160 and you'll need an adapter fitting p/n ATM-3280.
I think I've got a bad regulator. With the vac unhooked I can set it right at 38#. When I hook up the vac it drops to 28-29#. It will spike up to 32-34# when I rev up the motor.
I have not tried to adjust it with the vac line on yet. I will try that here shortly.
Do you thinks the regulator is bad? I have not tried to hookup the stock one yet to see what it does.
SaltWaterFish
208
Cedar Rapids, IA
Mar 28, 2004
  • Mar 28, 2004
Here is a pic of the gauge. Don't mind the dirty engine.
RIO5.0
6,892
N.H.
Mar 28, 2004
  • Mar 28, 2004
Roy....that gage dropping almost 10 lbs is correct with the vac re-connected......mine will do the same....as you drive it and step into it, watch the F/P rise towards your max reading....sounds like your ok to me...
SaltWaterFish
208
Cedar Rapids, IA
Mar 29, 2004
#10
  • Mar 29, 2004
  • #10
Thanks for your input Andy and you are right. I put my stock regulator back in and with the engine cold and the vac line on it put out 32#. Without vac it jumped right to 40#.
I'm guessing if I let the car warm up the idle will drop and give me a lower reading with the vac line on. So my Kirban (bought it used off E-Bay) is good.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Mar 29, 2004
#11
  • Mar 29, 2004
  • #11
Vacuum line off represents WOT pressure. Set it with the vacuum line on at whatever setting you want at idle.
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Fuel Bad regulator diaphragm?
  • JD1964
  • May 20, 2025
Fox 5.0 Mustang Tech Jul 16, 2025
JD1964
Fuel pressure regulator differences
  • dan50
  • Mar 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 26, 2026
dan50
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
