Fuel Sender Question
Ever since i did the engine swap and redid all the wiring in the car my fuel gauge hasn't worked. It worked before all of wiring i did. I am carbed now and i pulled out all of the computer wiring. I was wondering does the fuel sender wire directly into the dash gauge or does it run through the computer? Thanks
-AJ
The slosh module is the little circuit card plugged into the back of the instrument cluster.
Other areas to check:
Connectors
C207 - behind LH cowl panel
C400 - below rear of car above fuel tank
C410 - at sender
Splices
S400 - rear lamp harness somewhere around where G400 (below) comes out of the main harness.
Grounds
G400 - center rear of cargo area
