  • SN95 4.6L Mustang Tech
Fuel Setup Questions (for returnless)
  • Thread starter Thread starter RickieFrat
  • Start date Start date Oct 2, 2004
RickieFrat
328
State of Corruption - Providence, R.I. , USA
Oct 2, 2004
  • Oct 2, 2004
Ok ... I got a 96 GT with the return fuel setup. Bout couple months ago I installed a 2002 engine out of a convert. The motor was complete with everything needed. The motor that was in the car was tired from excessive nitrous use and the famed intake crack. I got a really good deal on the 02 engine so I went with that instead of dishing out $$ on the 96 block.
Well with the new block installed, I had to swap over some parts from the 96 motor for it to work. Like the coil packs, sensors, and the fuel rails.
I still have all the parts from the 02 engine that I took off. My plan is to change the CPU and put everything on the engine that was on it when I got it.
My buddy that sold me the engine said that he didn't have the CPU but had the fuel tank and pump for it. He told me that it would be needed for the returnless setup.
My questions here are ....
1) Would the tank bolt right up in place of the other.
2) Will the connectors work with what I have now to make the pump function.
3) Do I need to replace the line going from the tank to the new fuel rails.
Thanks in advance for the help !!!
showstopper2
425
New Bedford, Ma.
Oct 2, 2004
  • Oct 2, 2004
you will most likely need the line since its only one. the tank has a pretty extensive Evap system attached to it which also attaches to the left rear fender and filler tube. for all the work involved with that I would just stay return system like you have now since it offers you more options for pumps and other parts.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 2, 2004
  • Oct 2, 2004
stay with your return style , just get your ecm tuned for the new motor , it will be alot easier for future mods to just stick with what you have .....IMO ..the aftermarket is more return style friendly as far as fuel delivery and such items .....
lopey4.6
20+ Year Stangneter
Jan 4, 2004
309
Westlake,OH
Oct 2, 2004
  • Oct 2, 2004
Definetly stay return style. much easier to upgrade parts
RickieFrat
328
Oct 2, 2004
  • Oct 2, 2004
So if it go with a Bullitt intake, I can keep the fuel system return style ??
Also ..... I have to change the computer. The tranny I installed is out of the same car. (2002 Tremic) I currently don't have a speedo. The Tremic has a magnetic pick-up vs the manuel style (Borg-Warner) I had in the car. When I connected the sensor (on install), the car would shut off in third gear because the computer thought it was at max MPH. Kinda funny ....... 80 in first gear.
So i figured ... If I had to change everything in the process ...... might as well update the rest of it.
RickieFrat
328
Oct 3, 2004
  • Oct 3, 2004
ttt
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
