Fuel system upgrade quetsions!!
  • Thread starter Thread starter satanas
  • Start date Start date Dec 13, 2010
satanas
156
Arizona
Dec 13, 2010
  • Dec 13, 2010
I have some questions im installing a fuel system for my car and was wondering if i need a y block to run my lines to the fuel rails.. im running a Aeromotive fuel pump with 8an feed and 6an return..have a fuel pressure regulator also... Do i need y block or is there a way i can do this without it,,,any diagrams please if possible ... thanks everyone
87coupe50
105
WAYNESBORO, PA
Dec 14, 2010
  • Dec 14, 2010
for equality of fuel supply (and pressure) to the rails you would need a y-block with feed line to each rail, then from each rail to a bypass type regulator with the return back to the tank.
you could probably run a system like BBK (5010) (that adapts to the stock rails but using your aftermarket stuff), the regulator would have to hold pressure for the rail that doesn't get the direct fuel feed
Fuel Anyone know a part number for a 3/8" inlet/outlet efi quick connect fuel filter that would fit the stock foxbody location?
  • rednotch
  • Dec 8, 2025
Fox 5.0 Mustang Tech Dec 8, 2025
rednotch
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
A
Fuel Capable fuel system for +600hp
  • Avia.tuned
  • Feb 24, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 24, 2026
squeak93
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
