Fuel Tank Straps?
Silver95Stint
350
England
I finally have the parts that I need to change my fuel pump on my 93 LX. The only problem I am running into...I can't find replacement fuel Tank straps. The ones that are currently on the car are rusted and corroded, and need to be replaced when I replace the fuel pump. Where can I get fuel Tank Straps from? Any help would be greatly appreciated.
Thanks all who helped. I decided to go with gooch's advice and choose rock auto. They can deliver overseas and the price was 20.79. Thank yall again though, because I was really gettin a headache with this thing. Now if I can just get this tank off, I will be in business. How hard of a job is it to replace your fuel pump?
Make sure you REPLACE the o-rings. I used the old ones during a gas tank change and when I filled up with gas..... I lost a few gallons on the ground at the gas station. Make sure the pump comes with a new O-ring or buy a new one before installing. I actually had to take my tank off twice because of the stupid o-rings and the problem was is that I had a full tank the second time when the rings leaked! :bang: Don't take the sender out if you can help it, it would need a new o-ring too before reassembly.
Rick 91GT said:
www.behindbarsracecars.com
Chris make a awesome replacement tank, it is alum . He supplies new alum straps with the tank, I am sure they will sell them seperate if you want those.
what are the advantages of the aftermarket tank? i would like to see one, do u have a direct link?!??! is it the same capacity as stock and does everythign hook right back up? THANKS MAN!
The tank is alum and features a sump for running a external pump. THis is so guy can run a tank in the stock position, save some weight and not put in a cell.
Direct bolt it..
The pics do not do it justice, we have one going on our Cobra and it is a piece of art.
