Fuel Tank ??
  • Thread starter Thread starter Quick Pony
  • Start date Start date Oct 9, 2006
Quick Pony
129
Pensacola, Florida
Oct 9, 2006
  • Oct 9, 2006
I plan on replacing my fuel pump on my 1991 LX 5.0 convertible this weekend, which involves removing the gas tank. My wife called around to find out how much it would cost to have a "professional" do it. (She doesn't like me working on the car because I have a bad back). Anyway a mechanic told her it would be $185.00 labor because the axle has to be dropped for the gas tank to be removed!
Does the axle have to be dropped?
Thanks
Larry
1Bad88notch
62
Leesburg,FL
Oct 9, 2006
  • Oct 9, 2006
you dont need to remove the axle, the tank sits behind the axle. ive taken my tank out of my coupe a couple of times to fix leaks and didnt remove the axle. put the car up on jack stands and put the jack under the tank and unbolt the straps and let it down. its not that hard to do, also helps if you have someone to help you.
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Oct 9, 2006
  • Oct 9, 2006
Nope, no axle drop needed.
Just a jack to support the tank and it comes down fairly easy. Siphon the gas out first
diablostang
425
Raleigh, NC
Oct 9, 2006
  • Oct 9, 2006
False info there. The gas tank is 3 bolts. 1 bolt on 1 strap, 2 bolts on the other strap. Lower it slowly with a floorjack, and you'll be ready to rock.
351 82GT
430
  • Oct 9, 2006
Either that shop has complete idiots working for them or your wife lied about the axle drop to scare you out of doing it yourself.
If they had to drop the axle to replace the fuel pump, it would cost a hell of a lot more than $185 labor.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Oct 9, 2006
  • Oct 9, 2006
isn't there a little hatch door under the back seat to allow you to the sending unit.
351 82GT
430
  • Oct 10, 2006
I don't remember seeing a "door" under my back seat in my '88GT when I installed a power junction box under there for my stereo system.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Oct 10, 2006
  • Oct 10, 2006
I know alot of other Ford's had them...My 92 Tempo had one and a few other Ford's I have worked on had them. I thought I heard somewhere that our cars have one
z2o_what
309
princeton, WV
Oct 10, 2006
  • Oct 10, 2006
i was unaware the one of the straps had 2 bolts... someone must have already removed one of the bolts on my car.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Oct 10, 2006
#10
  • Oct 10, 2006
  • #10
Think about where the Fuel Tank was positioned in the Tempo compared to the Stang, if there was an access door to get to the Fuel Pump in the Stang it would have to be in the Hatch Floor and there is not.
z2o_what
309
princeton, WV
Oct 10, 2006
#11
  • Oct 10, 2006
  • #11
i dont think they have a door there, but if they had an access door it would need to be in the trunk/hatch area
edit: beat me to it
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Oct 10, 2006
#12
  • Oct 10, 2006
  • #12
There is no door. I've had my interior out plenty of times.
Some guys cut square holes in their floor in the rear so they can change pumps without dropping the tank. Not a bad idea really. Tack weld a couple hinges and a latch and easy fuel pump changes!!!
PhLoBuS
473
Beverly, MA
Nov 26, 2006
#13
  • Nov 26, 2006
  • #13
yeah it would cost alot more
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
