Fuse #18, what gives?
I've never had this problem up until recently, I got pulled over the other day and shut off my car for the cop. Well after going through all the BS I start my car and realize that my instrument cluster illuminations work, but the tach, oil pressure, temp, voltage, and fuel gauge all do not function. So ok, I realize the next day Fuse #18 was blown, so I replaced it. Gauges work when I put the key into the position where the fuel pump primes but right when I start the car, it blows again. Replaced it 3 times now, does it everytime when I start the car. How could this just happen out of nowhere? Any input?
You might have to just disconnecting things and seeing if it doesnt blow when it otherwise would. Or disconnect everything and hook things back up till it blows (this can be more work but uses less fuses).
Someone might know what's a likely cause to blow your fuse (good thing to check first). I dont.
Good luck.
Check the ground strap under the steering wheel. It should be right next to the console under the steering wheel. Its like a 10 gauge black wire. That is a junction point for alot of the interior electronics.
