  • Mustang Sound & Shine All
Fuse rating on my amps is too high for wiring kit...
  • Thread starter Thread starter O.D. Showtime
  • Start date Start date May 29, 2005
O
O.D. Showtime
820
  • May 29, 2005
I am using this Rockford wiring kit for my two amps: http://www.crutchfield.com/S-WWQGFl...w.asp?g=128900&id=essential_info&i=575CP4DCKS
My amps are both Kickers, one KX350.4 for the components and one KX 400.1 for the sub. The combined fuse rating for both amps is 80. According to the info on crutchfield, I should go out and get new fuses for the distribution block because my total fuse rating exceeds 60 amps. Will it matter though, what could happen if I don't upgrade my fuses? Also, are there any brand fuses I should avoid? Thanks.
MyEarsHurt
918
  • May 29, 2005
You need to match the fuse rating with the subs or have more fuse than necessary. If you dont have the correct fuses (too small of a fuse) I think you can catch your wiring on fire...
Infinity
956
Charlestown, IN
May 29, 2005
  • May 29, 2005
You're fine. If you blow the fuse, then change it with the higher value. Otherwise, it's sitting pretty.
Scorcher2005
883
South Carolina
Jun 1, 2005
  • Jun 1, 2005
you have that backwards. You dont want a overly high fuse rating value. fuses are meant to stop too MUCH current from coming through. Its much better to undervalue and have the <$1 fuse blow than overvalue and have to >$200 amp blow. to determine fuse rating, take amp wattage and divide by 12.
Infinity
956
Charlestown, IN
Jun 2, 2005
  • Jun 2, 2005
Actually, the fuse doesn't protect the amp in any way shape or form. The fuse is there to protect the wire itself. If the fuses start blowing, then there is either a short (cut in the insulation, touched ground) or the amp has ALREADY gone bad. The best idea is to match the fuse to the wire, provided you're running sufficient wire to your amplifiers. You'd be surprised how many people do not. Also, running undersized wire and not having an adequate ground path is the most common cause for headlight dimming.
Install Daytona Sensors CD-1 Ignition Mustang Fox SN95
  • revhead347
  • Sep 21, 2019
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
AeroCoupe
Routing Amp Power Cable
  • Berry
  • Oct 1, 2016
2K
1996 - 2004 SN95 Mustang -General/Talk- Oct 3, 2016
90sickfox
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
12K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
P
HELP! Cranks won't start!
  • ProfSnakes
  • Nov 4, 2011
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Nov 4, 2011
ProfSnakes
P
One small wire that feeds the whole car?
  • capri debris
  • Oct 22, 2010
Fox 5.0 Mustang Tech Oct 22, 2010
jrichker
