Gangsta lean!
  • Thread starter Thread starter iLkYsPoNy
  • Start date Start date Feb 27, 2007
1 of 2 Next Last
iLkYsPoNy
if she's a tranny then... well I'd do her.... it..
Aug 8, 2006
60
Sandusky, Ohio ( Cedar Point - America's Rockin' R
Feb 27, 2007
  • Feb 27, 2007
I just noticed the other day when I put my new wheels on the car that my passenger rear seems be about 1 inch lower than my drive rear... what's usually the cause of this? Anyone had a similar problem?
Should I replace the shock? The spring? Please advise because my car has a GANGSTA LEAN!
HISSIN50
34
129
Feb 27, 2007
  • Feb 27, 2007
Check the front heights as well. It's often a kitty-corner pitch issue. Like in your case, if the driver front is higher than the passenger front, this would be possible.
Otherwise, it can simply be a slightly tweaked unibody. Any hard maneuvers without SFC's can do it.
Good luck.
iLkYsPoNy
Aug 8, 2006
60
Feb 27, 2007
  • Feb 27, 2007
Well, thanks for the wish of luck! When I put my wheels and tires on I went in for an alignment and they told me that my driver front strut tower was pushed in too far so they couldn't correct the alignment perfectly. FYI, this car has been in a wreck about 14 years ago, which I knew about but didn't figure I would see any issues.. HA.
So now I have to set up with a body shop to get the thing pulled out and lined up. I guess I will wait to see how everything turns out before I start throwing parts at it.
I have the worst luck in the world....
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Feb 27, 2007
  • Feb 27, 2007
Actually the lean is quite common...the Corral had a 10page thread regarding the lean. Most came to the conclusion that the body had twisted to some degree though abuse was not always considered the cause. I know I have yet to see one car that sat perfect when the measuring tape came out...I myself have a 1/2 lean that remains even after all components were replaced front and back.
TomCat
412
Utah
Feb 27, 2007
  • Feb 27, 2007
Ditto... mine leaned before I wrecked it. Looks fine from a distance, but when you measure... drivers side sits about a half inch lower. Suspension is all brand new, too.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 27, 2007
  • Feb 27, 2007
Mine i believe also has a lean. But i installed Sub-Frame connectors as soon as I got the car. Un fortunetally You can't undo the 15 or 16 years worth of damgae the previuos owners had done. I just won't add to it.
iLkYsPoNy
Aug 8, 2006
60
Feb 27, 2007
  • Feb 27, 2007
I'll try and get some pictures up so you guys can see what I'm talking about. It's so drastic ( atleast in my picky eye ) that when I see it from a distance it looks like my right rear tire is flat. It pisses me off lol.
I will also try and get a pic up of the strut tower I mentioned. I never paid much attention to the paint line that visible from it being so far off.
HISSIN50
34
129
Feb 27, 2007
  • Feb 27, 2007
Derek, I rememeber that 10 pager - it was a doozy. Some threads have a DUW - that one should have had a ASW (ASpriin Warning). The off-pitch aspect I mentioned (though apparently not an issue for IP's ride) was one thing mentioned in that thread.
IP, don't read anything into my wishing you luck. I've probably said that 15K times in here (I almost always say it - it's means what it means and is not an indication of a CF).
Um, well, good luck.
mustanghrspower
554
Las Vegas, NV
Feb 27, 2007
  • Feb 27, 2007
The body being damaged probably doesn't help, but it may also be partially caused by broken coil springs. Both of my cars had a coil broken that I never saw until I changed the springs. Both were a front spring though. Sometimes you can't tell they're broken until they are removed because they break off down in the spiring pocket on the control arm.
H
habiv
125
#10
  • Feb 27, 2007
  • #10
frankenstang and i were just discussing the "lean" issue in a talk thred. I guess this is more common than I thought. Doesn't make me feel much better about it though I would love to rectify the issue.
D
DocZG
72
San Antonio, Texas
Feb 27, 2007
#11
  • Feb 27, 2007
  • #11
wouldnt it be possible to correct the lean when you install new subframes? you could support the chassis on 4 points with the two fronts being level with each other and the back being level with each other? i would imagine that the weight if the car would bend "untwist" the car. Then if you installed subframes with it evened out, i would imagine that it would correct most of it?
Im sure someone has tried this.... so im waiting to be shot down here
1990Coupe
1,462
132
114
Toms River NJ
Feb 27, 2007
#12
  • Feb 27, 2007
  • #12
i dont know if it would work that easily.. i almost think in some ways the car isnt heavy enough or its not bent in that way on the subframes. i have a reallllly bad ganster lean - im replacing all the springs (stock 1990 4 banger units) are in there now and im hoping thats the cause to most of my leaning problems
G
getusummm
156
#13
  • Feb 27, 2007
  • #13
Actually I think it would take more that just resting the body on stands. You would probably have to have it pulled. I just recently ran across a thread. The guy had the car on stands on level concrete. It was only hitting 3 of the 4 stands.
I do wonder if you could get it somewhat closer to even with coilovers. Probably not the best for traction, but at least you could have a little adjustment.
How far is the car from being aligned? Could caster/camber plates get it in spec without going to the frame shop? Or is the frame shop cheaper than the plates?
iLkYsPoNy
Aug 8, 2006
60
Feb 28, 2007
#14
  • Feb 28, 2007
  • #14
It's so far off it's gross lol. I'm not really familia with the process of an alignment, but I got to see the guys screen and it showed my little bar being off the scale, so I don't know. I have to get the whole strut tower pulled out, it's got about 1/4 inch of exposed paint. I am working on pics so you guys can understand.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 28, 2007
#15
  • Feb 28, 2007
  • #15
my car
look how bad my car sits it lean realy bad to the front. i dont know what to do about it. there is liek a 4"
difference dtween my coupe and my GT and they both have stock springs and on my coupe the fender is close to 4" above the back driver side tire an on the passenger side its like 2.5-3" and up front its 2" driver and 2.5" passenger. its like it has truck cols on it or something. i dont know what to do about it
http://www.cardomain.com/ride/2583193
302RollinHard
Columbus, OH
Feb 28, 2007
#16
  • Feb 28, 2007
  • #16
The driver front of my car will bind when I put it up on jacks/let it back down and make the passenger rear sit lower. It looks like I got friggin hydraulics on it until I start up the 351W and the solid motor mounts. Shakes it right down. To be that bad of a lean all the time that you describe and that BK has pictures of on his car, there has to be some suspension problems somewhere (broke spring, binding front/rear control arms) unless previous body damage is evident then it is time for the frame shop.
1990Coupe
1,462
132
114
Toms River NJ
Feb 28, 2007
#17
  • Feb 28, 2007
  • #17
http://www.cardomain.com/ride/2582320
im having a similar problem. only my car is leaning to the driver side front thus bringing the back passenger wheel well up. im hoping when i put new springs on this corrects it. my car was a 4 banger convert and the springs were never switched out so im hoping this is the problem.
R
rigamaroles
British Columbia
Feb 28, 2007
#18
  • Feb 28, 2007
  • #18
Mine leans as well, about 1/2 inch or so. I replaced all the suspension about 10,000 km ago, but did it from day one. To even it out I considered putting in a new isolator on one side and an old one on the other to "even it out."
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Feb 28, 2007
#19
  • Feb 28, 2007
  • #19
springs
thats what im hoping for too. im gonna put lowering springs on it and hope it drops A BUNCH it realistically need to come down 4-5"'s or so inches in the back and 3"'s or so in the front. and those springs ar way too stiff on ther now.
iLkYsPoNy
Aug 8, 2006
60
Feb 28, 2007
#20
  • Feb 28, 2007
  • #20
My buddy had a similar problem on his coupe that had a different rear end in it out of a thunderbird. His ass end was up real high, he put new control arms ( U & L ) then put different spring on and it didn't help much. Mind you they weren't lowering spring either. His solution? Buy bigger slicks...
Sincerly,
Mr. 10,012.
1 of 2 Next Last
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
Suspension Quad shocks
  • keel
  • May 20, 2026
Fox 5.0 Mustang Tech Sep 2, 2026
AeroCoupe
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Monday at 12:38 PM
Fox 5.0 Mustang Tech Tuesday at 7:31 PM
mikeah
