Garage Revamp!
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Since the Fox is at www.DPRsocal.com getting a custom single turbo attached to the www.RNHPerformance.com Dart stroker, I figured it was the perfect time to update the tiny 2 car garage I have. Take a look.
Before
After
I love it!
Thanks, it looks a million times better in person.
close shot
As for the Fox.
Dart 363 IE
AFR 205's
Jay Allen custom turbo cam
Canfield intake, Spyer style
PT76-GTS turbo
Viper T56
Sumped tank with Weldon pump
MM K member, A arms, front coil overs, Bilsteins all around.
31 spline axles, True Trac diff, 3.27 gears
and all the supporting hardware...
The F250 is all set up for the lift, I have 35x12.50x18 Toyo's mounted on 18x9 Sendel wheels. I am going with the Donahoe Racing 4.5" lift and am waiting on the rear lift block, I have everything else :)
18x20 garage total was around 1k, The prep work was crazy, they sanded the entire floor with some sort of diamond blade, tons of dust! From what I have read the acid etching simply cannot compare to the actual sanding of the floor. Also be sure to get a clear coat or the sun will fade the epoxy, I had a friend do his house without the top coating and the first few feet are badly faded due to sunlight.
Good luck, and yes I think it was worth every penny.
you guys are lucky, in order to do that to my garage it would probably be $3k because mines 20'x50'...i guess ill just stick with my concrete floor for now..at least the place is heated. such a mess right now though....me and my dad need to clean it out
Thanks for the info!
