  • SN95 4.6L Mustang Tech
gas cap
  • Thread starter Thread starter 40thmustanggt
  • Start date Start date May 21, 2007
40thmustanggt
34
  • May 21, 2007
i can't get my damn gas cap light to turn off and its bugging me im thinking maybe a sensor went bad?? ive tried everything i can think of ive tried taking it off and putting it back on with the car running and off.. nothing seems to help i went to autozone and got them to turn it off i stoped and filled up sunday and it came back on this morning on the way to work.. whats the deal? i even tried a new gas cap.. can someone help me with this??
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 21, 2007
  • May 21, 2007
Gas cap light?
40thmustanggt
34
  • May 21, 2007
Kilgore Trout said:
Gas cap light?
yep i have a light on saying check fuel cap
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 21, 2007
  • May 21, 2007
http://www.modularfords.com/forums/2003-2004-mustang-cobra/check-fuel-cap-light-on-8219.html
40thmustanggt
34
  • May 21, 2007
so maybe its a bad cap?? try the new one and reset it and if it comes back on its the evac tube??
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 21, 2007
  • May 21, 2007
I thought you said you already tried a new cap?
If you have not tried a new cap of course that would be the first thing to try...
40thmustanggt
34
  • May 21, 2007
well i mean i bought it today and just put it on i didnt know it took a few times driving before it would shut off so i just put the old cap back on
40thmustanggt
34
  • May 21, 2007
what is a evac tube ?
Tim2002GT
635
Tulsa, Oklahoma
May 21, 2007
  • May 21, 2007
Check all of your 20amp fuses(inside of car). I had one blow and it kept giving me the same error code.
ToplessStang
591
Montreal, Canada
May 21, 2007
#10
  • May 21, 2007
  • #10
Cars today have a closed fuel system which also means fuel vapors are no longer released into the atmosphere but kept in the cars evap system, stored in an evap canister and then sent back into the engine to be burned.
The PCM will run a test on this system every so often and check if the system can hold vacuum. If it does not, it assumes a leak is present (ie. gas cap not closed) and lights either the CEL or in your case Gas Cap Light. Other than making sure you gas cap O-ring is in good shape and your cap is closed properly, there isn't much else you can do unless you really know how the system operates and what you are looking for.
You can jack up the driver side rear of the car and behind the rear tire you'll see the canister. Take a look and make sure the rubber hoses are all properlly installed. If all looks well you're going to have to take it in.
I would recommend the dealer as they have whats known as a "smoke machine" for this type of problem where they close up the system, add smoke into it and check for the leak. Can be a defective CV valve, VMV and a few other things that a do it yourselfer just can't check.
Good luck and let us know.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 21, 2007
#11
  • May 21, 2007
  • #11
Great tech
Great advice, sometimes road debris can fly up and damage that stuff.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
May 21, 2007
#12
  • May 21, 2007
  • #12
Anyone else find it silly that Ford removed a LOW COOLANT warning light and substituted it with a "Check gas cap" light???
I mean what is more important here???
40thmustanggt
34
#13
  • May 21, 2007
  • #13
jesus i just bought the car this sucks.. i called them and im taking it in next tuesday..
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
