gas gauge problem
  • Thread starter Thread starter Final5pt0
  • Start date Start date Jan 31, 2007
Final5pt0
38
  • Jan 31, 2007
my 87 GT has a problem with the gas gauge, it is always reading at a full tank, and the dummy light for low fuel only comes on when there is 1/16 a talk left or less, i know its supposed to light up before that
so...
whats wrong? and what do i have to buy/do to fix the problem
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jan 31, 2007
  • Jan 31, 2007
Most likely your fuel level sender has gone bad. This is a common problem on these cars. What usually happens is that the fuel level sender gets an open in the circuit. An open makes it have infinite resistance which causes the gauge to always read above the full mark. You can get a new sender from Ford or several restoration companies have them. You will have to drop the fuel tank in order to replace the sending unit. You might want to go ahead and replace the fuel pump while you are there.
KcMstang
1,563
Hamilton, Georgia
Jan 31, 2007
  • Jan 31, 2007
I'm dropping my tank this weekend with plans to make sure the strainer is not clogged and to change my fuel-sending unit. Does part places like Advance NOT carry the sending units...not wanting to go through Ford! I plan on a blower later on down the road so I don't want to have to buy two fuel pumps.
bullitstang1313
713
Jan 31, 2007
  • Jan 31, 2007
I don't think you can get them from a regular auto parts store. Its usually a special order item even if they can get it. 5.0 Restoration Supply sells them. Here is the link: http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-9275B 1&comp=LRS
If you plan on going boosted down the road, you might as well get the 255 LPH fuel pump now that way you don't have to do it later.
KcMstang
1,563
Hamilton, Georgia
Jan 31, 2007
  • Jan 31, 2007
Can I run the 255lp fuel pump now even though it might be awhile before I get the blower? Thought the car would run too rich!
bullitstang1313
713
Jan 31, 2007
  • Jan 31, 2007
No, the car should still run just fine as long as your fuel pressure is set correctly and your regulator works. All you are doing is flowing more fuel to the rails. Since there is a fuel return line, you will just flow the extra fuel back to the tank.
KcMstang
1,563
Hamilton, Georgia
Jan 31, 2007
  • Jan 31, 2007
Appreciate the help! Going to go ahead about order the 255lph pump and sending unit from 50resto.com tonight!
Final5pt0
38
  • Jan 31, 2007
so if i change that fuel level sender it will mostlikely fix the problem?
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
