Hi guys,
Okay, so I am having the worst week of my life. I owe my mom $2,500 CAD because I used her truck, and accidentally slid on some ice and smashed her rim into a curb, wrecking her control arm, bearing, rim, tire, and inner fender protector.
Now, to top it all off, I found out my car (which is parked in my garage due to Winter), is leaking gas. It appears to be leaking from the filler neck (where it connects to the actual gas tank). The outside plastic covering the metal filler neck tube is covered with liquid (gas). Sooo, as some of you know I live at home. My mom wants the car out of the garage, and parked in the driveway. Since I am taking it out, I figured maybe I should just drive through the salt/snow and take it to the dealership to fix this problem. The only issue is that I don't have alot of money right now (I'm a student) to pay for this "fix".
So anyways, my question is this: How is the filler neck attached to the gas tank? Is it welded? If so, it will obviously cost alot since a mechanic can't weld the neck to the tank with gas in it. If it is not welded, how is it connected? Is it easy/inexpensive to replace?
Thanks for your insight guys,
Matt
Matt
