  • SN95 4.6L Mustang Tech
gas tank problem
  • Thread starter Thread starter WRXracer
  • Start date Start date Mar 20, 2004
WRXracer
825
  • Mar 20, 2004
ok I have a problem with my car when I have under qaurter tank.. it runs horrible and bucks.. is that normal when having a blower.. I have a 255 pump 42 lb injectors and it is tune right.. could it be my fuel filter I have never changed it.. or is the fuel pressure just too low..
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Mar 20, 2004
  • Mar 20, 2004
first of all, change your fuel filter. 2nd, when your tank gets below 1/4 tank, you are losing fuel pressure. get a fuel pressuer gauge. the only way to avoid the 1/4 tank problem is to go with the 03/04 Cobra tank and pump.
stangman
2,690
10
69
in a 3 bed, 2 bath
Mar 20, 2004
  • Mar 20, 2004
if i were you i wouldn't take mine below a 1/4 at any time if possible, especially with your setup. the gas in your tank actually keeps the pump cool & at operating temperature. if you go below a 1/4 tank you have no way to cool the pump, which can lead to pump failure, due to over heating. & with your setup it's working much harder to flow fuel, so i would imagine it has the potential to cause a lot more problems because it would naturally get hotter with you setup. but first & foremost CHANGE THAT FILTER
neoclasiccl
3,043
Help I can't see !!!!!!
Mar 20, 2004
  • Mar 20, 2004
That's the rule of thumb with the Pumps in a GT tank. never go into boost Lower than 1/4 tank and never go below 1/8 tank. You run dry that means lean and motor go boom
WRXracer
825
  • Mar 20, 2004
ok
ok just got it changed.. oh my god.. feels like I have 50 more hp..
MT1083
1,033
Charlotte, NC
Mar 20, 2004
  • Mar 20, 2004
Yep. KB manual says never to go into boost with less than a 1/4 tank. It can cause the fuel pump to cavitate.
DeadLurker
Daily Driven
Sep 7, 2001
7,702
New York
Mar 20, 2004
  • Mar 20, 2004
I just switched to the 03 cobra pump/tank and I still dont' boost it below 1/4th a tank.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
A
87 GT - Low Fuel Pressure Problem
  • Asbury
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
