Engine Gasket For Stock Upper Intake Without Egr Hole In Center?
JohnnyK81
83
Hey guys, does anyone know if there is a gasket that will work on the stock upper intake (to lower intake) that does NOT have the center hole punchout for the egr?
THanks!
None.
I assume you wish to block the EGR flow? Get a razor blade and remove the fat edge of the blade (if equipped). Add a little RTV and rtv it to the lower intake. Then install gasket and upper as usual.
Any thin peice of metal that will not degrade and fall inside can be used.
There are lower intake gasket kits that will block the flow at the head, but that would require removing the lower.
Thanks guys. Crap.. I thought for sure there would be one. I guess I could tap and plug.. Probably easier just to turn down a piece of aluminum and tap it in though.
I've done both of those methods which work fine you can also find a freeze plug to tap in there. You can buy a intake spacer that does not have the EGR passage also
Sent from my XT907 using Tapatalk 2
Ehh I'll grab one later this week. Problem is on a 67, the shock towers cause clearance problems, so with the EGR spacer, the intake tube will run right into it with no room to bend towards the front of the car.
