Gasket Kits or Seperately?
fel-pro has some really nice gasket kits now. they have a 1 piece pan gasket that is silicon on metal with reinforced area round each bolt for pan. they have awesome head gaskets aswell. i like there intake gaskets for carb'd engines. i have nothing but good to say about the gaskets they are pumping out right now.
Personally I use a Fel-Pro 2718 R.A.C.E set (rear seal, front seal, timing gasket, water pump, oil pump, fuel pump if needed, and thermo) $24
I would use a Fel-Pro 1011-1 Head gasket on your motor $32/each
I assume the Weiand is a Fel-Pro is a 1250 gasket size although those Holleys are most likely a 1262 so you'll need the 1262 gasket $20
The Oil Pan gasket I use is the thick re-enforced Fel-Pro mentioned above it is OS34508R $32
Header gaskets Fel-Pro 1415 $20
The only issue with the Ford kit for you is that some of the gaskets will be too small since they are made for a stock motor, intake, headers, etc..otherwise I have used that kit and it is very nice they are Fel-Pro gaskets.
i been buying my gasket kits seprately, i noticed i get better gaskets and the gaskets i want to use with my setup, most gaskets come with larger ports and so on, plus in that kit you get alot of gaskets that are not needed. sometimes i noticed it comes out cheaper buying them seperate and get better quality gaskets that i preffer, summit has some good deals on one piece oil pan and valve cover gaskets, joe
