gauge cluster
  • Thread starter Thread starter 02TruBlueGt
  • Start date Start date Aug 28, 2006
02TruBlueGt
  • Aug 28, 2006
quick ?? i have a 85mph top speed cluster in my gt (it was swapped in when i bought it) could i just swap in a 140mph one and be good or do i have to do some wiring??
bill302
2,131
alabama,gadsden
Aug 28, 2006
  • Aug 28, 2006
click on link one like this will plug up ,factory 87-93 instrument clusters will fit...with no modifications
http://cgi.ebay.com/ebaymotors/87-9...4QQihZ003QQcategoryZ33675QQrdZ1QQcmdZViewItem
02TruBlueGt
  • Aug 28, 2006
thanx alot i thought i would have to rewire something since i didnt have a 90-93 i thought i saw somewhere they had different wiring
trbkrb
1,976
Houston, TX
Aug 28, 2006
  • Aug 28, 2006
That exact cluster on ebay will fit in an 87-89 car. The 87-89 have a flat bottom on the cluster. 89 only had the 140 speedo. And you are correct, the 90-93 do have different wiring requirements, and an arch cut out on the bottom. They can be made to fit by rewiring the connectors, but it is not an exact drop in fit. See the revision to the ebay ad.
dls322
149
Mt. Penn, PA
Sep 8, 2006
  • Sep 8, 2006
Don't you need to get a new speedo gear too? If your switching from the 85 to the 140?
trbkrb
1,976
Houston, TX
Sep 8, 2006
  • Sep 8, 2006
No, if you are not making any other changes. The stock speedos (85 and 140)are calibrated to count the same number of cable turns for any given speed. You only need a new speedo cable gear if you swap out the rear end gears or change the drive gear inside the tranny on the output shaft to a different one (6,7,or 8 tooth gears).
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Interior and Upholstery 1993 Instrument Cluster cover
  • KevinV
  • Jul 2, 2026
Fox 5.0 Mustang Tech Jul 3, 2026
AeroCoupe
M
Gauge cluster
  • MadMatt7
  • Nov 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 9, 2026
keel
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
