Gauge Replacement
  • Thread starter Thread starter dbdragracing
  • Start date Start date Sep 12, 2005
dbdragracing
397
Sep 12, 2005
  • Sep 12, 2005
Im going to replace all my gauges and add a few more(even before I need them so they all will match). The stock tach and engine temp are already broken. I plan on having:
-speedometer
-tach
-engine temp
-oil pressure
-fuel level
-voltage
-boost
-tranny temp
-fuel pressure
-?fuel/air ratio?
A couple questions before I order them:
Which gauges are manual or electric?
Do they plug in using factory wiring (the guages that are already there)?
Thanks.
HISSIN50
34
129
Sep 12, 2005
  • Sep 12, 2005
Oil temp is a good one too.
For hook up, you will likely have to use your own wiring for some of them (you can reuse some wiring that go to the stock gauges, if you want. I wouldnt).
The choice of elec vs mech is all up to you. Just decide how you want the sweeps to look before you get all set with one particular gauge (so it all matches).
Good luck.
T
Tony90hatch
10
  • Sep 12, 2005
Check these out:
http://mc-machine.com/87dash/87dash.htm
I have these and you need to cut your stock wiring harness and rewire it all your self. Good way to replace stock gauges. I can find a wiring diagram that shows the color of wires and what they do so you know what to hook the new gauges up to. All should be analog electrical and the spedometer is the only mechanical one. Those plates are nice because you can put the gauge anywhere.
HISSIN50
34
129
Sep 12, 2005
  • Sep 12, 2005
Tony, interesting stuff.
An alternative would be something like the Florida5.0 cluster. This seems much more economical.
dbdragracing
397
Sep 12, 2005
  • Sep 12, 2005
Where do I find the electrical diagram so I know what all the wires are for behind the dash? Thanks for all the help...I think Im going to go with the Auto Meter SPORT-COMP or PRO-COMP gauges!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 12, 2005
  • Sep 12, 2005
Try this...
See http://secure.florida50.com/cgi-bin/raceshop/cat12.html?id=UqWPLH5I for the full story.
T
Tony90hatch
10
  • Sep 12, 2005
Wiring Diagram
dbdragracing
397
Sep 12, 2005
  • Sep 12, 2005
Thanks very much...That will be a big help.
dbdragracing
397
Sep 12, 2005
  • Sep 12, 2005
Out of the stock gauges...which ones are mechanical and which ones are electric? Thanks.
T
Tony90hatch
10
#10
  • Sep 12, 2005
  • #10
spedo is mechanical (uses cable)
Everything else is electric.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
