  • SN95 4.6L Mustang Tech
Gear bearing kit
  • Thread starter Thread starter Skidzz
  • Start date Start date Dec 14, 2006
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Dec 14, 2006
  • Dec 14, 2006
After Christmas is over with, I'm finally going to buy my 4.10's. I'm getting the package from AmericanMuscle with the frpp 4.10's, speedcal, and oil. My question is, should I buy the Motive bearing kit that they offer on the site? My car has 74k miles on it.
01BlkGT
1,015
ATX
Dec 14, 2006
  • Dec 14, 2006
Short answer....yes!
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Dec 14, 2006
  • Dec 14, 2006
Thanks
steveb24
555
wilmington, DE
Dec 14, 2006
  • Dec 14, 2006
even shorter answer.. no. you do not need new bearings.
merc123
420
North GA
Dec 14, 2006
  • Dec 14, 2006
Ford had to replace my pinion bearing and a few other bearings when they did my gear install.
bluextc
99
South Jersey
Dec 14, 2006
  • Dec 14, 2006
The shop I'm going to is replacing my bearings. My car has 39,000 miles.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Dec 14, 2006
  • Dec 14, 2006
well it all depends on the condition of the bearings i only replace them on cars that are close to 100K or they look worn or damaged........but if you want reassurance then yes i would have them replaced
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 14, 2006
  • Dec 14, 2006
It's ALWAYS a good idea to do bearings when doing a ring/pinion install. Everything comes out anyway so it is just automatic....it would be silly not to regardless of the mileage.
It also makes setting the backlash and pinion depth much more accurate.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 14, 2006
  • Dec 14, 2006
Accidental double post - Mods can delete.
steveb24
555
wilmington, DE
Dec 15, 2006
#10
  • Dec 15, 2006
  • #10
ive talked to two late model mustang performance shops in my area.. ironically.. evoulution performance, and performance evolution. ive dealt with both for over a year now, and talked to them about many many topics, such as bearings. each has done over 100 gear swaps, and "has never seen bad bearings on a mustang". yes they are right in front of your face, but its an unnessecary 80 dollars to spend. well i took there advice, im at 60k, and everything seems fine, and theres still 2 black stripes being laid everywhere i go. he said even on his 180k mile fox the bearings were still good. idk bout you guys, but im with them.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 15, 2006
#11
  • Dec 15, 2006
  • #11
Doesn't matter if they have done 1000's of gear swaps. All it takes is one. And if you happen to be that one, I can guarantee you will be wishing you had spent that $80 on a bearing kit.
It's as cheap as insurance gets.
And like I said, shops that actually have professionally trained techs in regards to rear end work will automatically do bearings when doing a ring/pinion gear install no questions asked. Pinion depth, backlash, and preload are all critical measurements. Backlash is adjusted to within .001" increments and the pinion and carrier bearing's preload is measured in in/lbs.
New bearings make these critical measurements/adjustments much easier and much more accurate making for a more reliable, efficient, and quieter rear end.
triggz
1,218
Gadsden, AL
Dec 15, 2006
#12
  • Dec 15, 2006
  • #12
Unless you're up to some pretty high mileage, there is no need to replace them. If you're going to do it anyway, PLEASE get the FORD parts and not Motive.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 15, 2006
#13
  • Dec 15, 2006
  • #13
The Timken bearing kit for the 8.8" is the way to go.
Also if you have the money, I would recommend one of these:
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=6409
lexluthr69
73
Huntingdon, CAMBS, UK
Dec 15, 2006
#14
  • Dec 15, 2006
  • #14
I'd have to agree that you should replace your bearings only IF they are actually showing signs of wear. The comment that it only takes one mistake in a 1000 to make it worth the extra money and effort, is comparable to the same ratio of defective bearings in a batch of good ones. "You never know..." doesn't always cut it when it comes to replacing parts unnecessarily. There's always that chance of getting a bad part. Why replace known good bearings with bearings that have yet to be tempered and set?
My 2 cents...
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Dec 15, 2006
#15
  • Dec 15, 2006
  • #15
Ok, here is another question, does anyone know of a reputable place in WV to have them installed? I was just thinking of having Midway Ford do the work, unless there is somewhere better to take it.
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
