  • 1994 - 1995 Specific Tech
Gear install kits
  • Thread starter Thread starter drewzx3
  • Start date Start date Jun 6, 2007
D
drewzx3
411
Louisiana
Jun 6, 2007
  • Jun 6, 2007
What install kit do I need to get for intalling my gears? Should I get the one that comes with everything or what? I know I'm going to get a traction lok rebuild kit
drakesdad
961
Oregon OHIO
Jun 6, 2007
  • Jun 6, 2007
Jegs and motive gear has one for a little over 200.00 that comes with all u need...including axle bearing...spacers for backlash....friction mod.....
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jun 6, 2007
  • Jun 6, 2007
I got this and it had everything I needed.
http://www.buyfordracing.com/shop/product_info.php?products_id=463
M
mgcook
40
  • Jun 7, 2007
i got my motive gears, motive install kit with axle bearing and seals for $250ish shipped from Brenspeed
94-302-vert
1,947
NE CT
Jun 8, 2007
  • Jun 8, 2007
When i was looking mustangs unlimited had some good deals... Here is one of the rear install sets..
http://mustangsunlimited.com/itemdy...ain&subCategory=Gaskets/Hardware&CatKey=74-01
Whole kit with gears:
http://mustangsunlimited.com/itemdy01.asp?T1=MG49+01&Category=&catkey=74-01
I like MU since they are kinda local for me...
The Green GT
1,269
Louisiana
Jun 8, 2007
  • Jun 8, 2007
Another thing. Ford Racing gears are less liekly to cause problems. THey are produced with much tighter margins of error. I spend the extra money and forked over $330 for gears, install kit, and trak lok rebuild from www.buyfordracing.com.
M
mgcook
40
  • Jun 8, 2007
im pretty sure motive makes ford racing gears
so you are basically paying more money for the same gears.
either way dont get richmond...they are too noisey
D
drewzx3
411
Louisiana
Jun 8, 2007
  • Jun 8, 2007
I went ahead and bought the frpp 3.73's I got the money for the install kit and traction lok just gotta get the money to get them put in.
94-302-vert
1,947
NE CT
Jun 8, 2007
  • Jun 8, 2007
Do the research.. if you got FRPP gears and have a decent tool set you can do your own gears... I wish I had... it would have saved me a TON of headaches...
D
drewzx3
411
Louisiana
Jun 8, 2007
#10
  • Jun 8, 2007
  • #10
I know a good place to get them put in I'm just going to let them do it because I know they know what they are doing. Do I need to get the install kit with axle bearings and seals?
94-302-vert
1,947
NE CT
Jun 8, 2007
#11
  • Jun 8, 2007
  • #11
I thought the same thing... I wouldn't let anyone else do this for me... Not even if it was free... That is due to the pain I felt (and continue to feel when going excessively fast)...
True 5.0
237
Southeastern Wisconsin
Jun 8, 2007
#12
  • Jun 8, 2007
  • #12
It only makes sense to replace everything while the rear end is torn apart.
FWIW - Richmond gears are awesome. They are pre-fit on a computerized machine and the pinion depth and shim values engraved on the gears. This makes setting them up super easy if you have the pinion depth indicator. Also, Ratech makes a inexpensive installation kit.
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
