  • 1994 - 1995 Specific Tech
Gear install
  • Thread starter Thread starter fiveo'cobra
  • Start date Start date Oct 25, 2004
F
fiveo'cobra
241
SC
Oct 25, 2004
  • Oct 25, 2004
My car has 95K miles on it and i'm about to do a 4:10 install. I've heard from many people that you need to buy the right size shims along with the gears to avoid problems down the road, but now i'm hearing something different. A shop is telling me that you are not supposed to mess with the shims unless you absolutley have to. So my question is, what did you guys do? What is the right way to do it? Shims or no shims? sizes? etc etc etc
thanks all.
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Oct 25, 2004
  • Oct 25, 2004
Each car will be different... I reused all of the stock shims with no problems as of yet... As long as its shimmed right, you wont get any sounds coming from the rearend. We ended up swaping the shims from the left over to the right, and from the right over to the left and everything measured up correctly. Unless you have the proper tools, I would suggest you NOT do this install by yourself. You need tools to measure pinion depth, need a inch pound torque wrench, ft pount torque wrench, I think a caliper to measure the shimming of parts, and a few other standard tools. Took me and my dad about 4 hours to rebuild the track-lock and install new gears.
F
fiveo'cobra
241
SC
Oct 26, 2004
  • Oct 26, 2004
thanks man.
HISSIN50
34
129
Oct 26, 2004
  • Oct 26, 2004
FWIW, if interested in reading about the ins and outs, Scott (Mo Dingo) has a link in his sig from his experience doing his. i thought he did a nice write up.
TrueBlue95GT
966
Connecticut
Oct 26, 2004
  • Oct 26, 2004
The writeup I used:
http://www.angelfire.com/theforce/5ohcpa/cpa5ohtech001.htm
F
fiveo'cobra
241
SC
Oct 26, 2004
  • Oct 26, 2004
Wow, that site kicks ass. Thanks TrueBlue.
One last Q would be for you guys with 4:10's. Are any of you running them without a speed calibrator?? How big of a differnece does it make with that? Like how bad is the speedo off?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Oct 26, 2004
  • Oct 26, 2004
Yep, there should be absolutely no need to change the carrier shims. They are two really big shims, one on each side. After you setup the dial indicator & measure the backlash, if you are within spec, then you don't need to mess with the carrier shims.
The gears don't come with carrier shims anyway, so you would need to go buy some from Ford. I didn't need to b/c my backlash was within spec.
The shim you do need to change is the pinion shim. This is done by measuring the pinion heads on both the new & old pinion with a dial or digital caliper. If the new pinion is taller, you need to remove some from the total thickness from the shims. If the new pinion is smaller, you need more thickness.
i.e. if the new pinion is .001 smaller , you need to add .001 to the new pinion to ensure proper pinion depth. The stock shim will be a big one, so you can just replace it with 2 smaller shims that equal the total thickness required.
Check out the link in my sig for more information.
Scott
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
