Drivetrain Downshifting from 3rd to 2nd issue
Scott_S
88
84
28
Rock Hill, SC
Down shifting issue. Give me your best virtual diagnosis.
My punch list is getting smaller and all the easy stuff is almost done. The biggest issue I'm having for drivability is when downshifting from 3rd to 2nd.
Shifting UP through the gears is fine. But, when coming DOWN from 3rd to 2nd, it's nearly impossible to get it into 2nd gear. I have to slow almost to the point of just choosing 1st gear instead.
It never grinds, doesn't pop out of gear, etc.
I tried adjusting the clutch at the firewall. The car is in the shop right now for some fluid changes and I've asked them to do a proper clutch adjustment while it's on the lift.
In your experience, do I have a clutch issue, or a transmission issue? I would think that if it's bad synchros or something, it would grind. What should I prepare myself for here?
My experience with manual transmissions is that 2nd gear gets the biggest workout of all the gears.... Banging 2nd gear the most often and downshifting into 2nd for a slow down so its the gear that gets used the most " in my experience" ... Back in my day, when we would go to a Wrecking yard and pull a 4 speed out of a wrecked car for $100, the 2nd gear usually ground into gear and sometimes popped out....
Just a guess here....
Also, how many miles are on the transmission? For that matter what year car are we dealing with? What brand and series of clutch is it and how many miles are on it? Has the transmission ever been gone through? Stock or aftermarket shifter and if aftermarket which one?
Car is a 1989. I think that it was originally an automatic and has been swapped.
Unfortunately, I don't have any history on the car. I don't know what heads or cam are on it. I don't know how many miles are on the transmission.
Any other issues with the transmission at all? I would be curious to see what the fluid looks like. If it’s a Borg Warner unit (Tremec bought them in 1995 maybe 1996) and you do not know the condition then it may time for an overhaul. See how things come out after the service you are having done. If you still have problems then you need to pull it and do an inspection. The longer you let it go the more it will cost.
Service manual is here (you have to click on “download”:
Really good videos on going through a T5:
Part 1
View: https://youtu.be/XREsRG9Y1mU?si=2mRJORjUp0UHUvAE
Part 2
View: https://youtu.be/mR8LetFQSoc?si=OQqJoHQ4zVf-dnJH
Part 3
View: https://youtu.be/BhbI4c6UFiQ?si=F_JF3xJteCOsSi9Z
Paul is a wealth of knowledge and Eric is pretty entertaining.
Most likely clutch adjustment (hopefully) or synchros. If the clutch adjustment doesn’t get it then I’d plan on pulling it and doing some looking.
I just throw it in to neutral when slowing down.
To save synchros from getting fried .
Clutch adjustment helped, but only a tiny bit.
My mechanic (who doesn't do transmission work) suspects 2nd gear synchro. There's a highly reputable transmission shop in town that's been here forever.
Other than the synchros, educate me on what to expect. Are there other wear items that would be dumb to not replace? And while I don't suspect any clutch issues, is this one of those "while you're in there" situations?
I'm not looking to cheap out, but I'm also not looking for a reason to spend money. What's the smart, logical approach to a transmission repair?
Save your money and put either a Z spec T5 or a Tremec TKX in it. Rebuild kits are damn near $500 and don’t come with all the bearings anymore. Then you still need synchros and who knows what else when you open it up. While you are in there you should put a billet cluster shaft support in it which are $65. So call it $700 in parts plus the labor. You would be damn close to the cost of a new Z Spec T5 that would just drop in and it’s something g you can do yourself.
Well, after the clutch adjustment, the problem got even worse. It got hard to find 1st OR 2nd at a stop, and reverse would grind a little in the driveway. It didn't do that before.
I had it hauled to a local, well respected transmission shop. Their initial diagnosis: They're 95% sure it's all clutch related and that the transmission is fine. I ordered a clutch master kit, throw out bearing, rear main seal, etc. Fingers crossed that's all it is!
Reactions: AeroCoupe and gkomo
I updated my Project post, but wanted to update here, too.
After replacing the clutch, flywheel, etc., it helped and shifted smooth .... until it got hot. Even the transmission shop was stumped; they were willing to bet a clutch would have fixed it.
Long story short, they got behind, lost a tech, etc., and the car was just today being pulled back into the bay. After talking to them about parts availability, etc., I did what I should have done two weeks ago and ordered a new T-5 from LMR.
Fingers crossed that I can get it back by the end of the month.
Reactions: gkomo and limp
Is it the Z-Spec T5 from lmr?
Generally speaking, one good way to see if things a clutch engagement issue vs trans is if you push the clutch in and just wait 10-15 seconds or so and then try to into gear or reverse. If the clutch fully disengages it should allow enough time for the trans to spin down and for the gear shift to be seamless.
If the clutch is dragging, it usually keeps the input gear spinning which spins the counter gear and speed gears and you’ll get grinding even after the delay.
Reverse gear is not synchronized. 92-later cars do have a “brake” so don’t put too much weight into it if you grind reverse easily.
Reactions: limp
Yes, I believe so. It's this one: https://lmr.com/item/LRS-7003A/mustang-t5-transmission-79-93
That's good to hear, because I also have 4.10's!
You will love the pull you get while in 3rd gear it's amazing. Feels like I picked up 50 horses to the rear with my 4.10's. For passing or merging onto the freeway leave it in 3rd gear put the pedal to the floor and feel the pull so awesome.....my shift light is set with a 5200 rpm pill then i shift into 4th.
The freeway with 4:10's??
