  • SN95 4.6L Mustang Tech
Gear Installation?
  • Thread starter Thread starter MGSTANG
  • Start date Start date Mar 14, 2004
MGSTANG
383
Palm Bay Fl
Mar 14, 2004
  • Mar 14, 2004
If you only have 3000 miles, do you have have to use the installation kit for new gears? Or can you just replace the gears and use the stock bearings and everthing? (Comes with pinion nut and shims)
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 14, 2004
  • Mar 14, 2004
should be fine with that many miles
MGSTANG
383
Palm Bay Fl
Mar 14, 2004
  • Mar 14, 2004
I just wanted to make sure I didn't have to get anything else but gears. Thanks alot
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
O
8.8 Pinion Nut Leak
  • OX1
  • Jan 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
OX1
O
