  • SN95 4.6L Mustang Tech
Gear swap problem!
  • Thread starter Thread starter VelR5.0
  • Start date Start date Nov 14, 2004
V
VelR5.0
25
SC
Nov 14, 2004
  • Nov 14, 2004
Hey guys this weekend I decide to install a set of 4.10 gear and ran into some problems Well first of all I don't have a micrometer but a caliper which is not as acurate to measure the pinion head or shims. After I pulled the old pinion I took a measurement at the head and then the new one and it looked close. So I did the same with the factory shim and the only one that looked alike in the FMS kit was the .030. To make the story short after I installed the pinion to specs with the new shim and crush sleeve the carrier will not turn!!!! I was told from a lot of people to reuse the stock shim, well I did, I guess since like I'm taking measurements with a caliper and the shim that looked the same size as the factory one was the .030. So what do you guys recommend? My friend told me to install a thinner shim, but will a .002 make a big difference since a lot of people go by that? Please don't tell me to take it to a shop, because I'm in a shop borrowing space and the car has to stay there untill tuesday and I'm paying daily for it . Please any suggestions will be greatly appreciated!!!
Velez
V
VelR5.0
25
SC
Nov 15, 2004
  • Nov 15, 2004
Anybody???
H
HIGDON
241
Ft. Hood, TX
Nov 15, 2004
  • Nov 15, 2004
Hey man. I've done quite a few gear swaps. FMS gears right? Well take the stock shim and OLD crush sleeve and install the new pinion. Now install the new nut until it sucks the pinion up and bottoms out against the old shim. Use locktite here. (should be some on the nut in the kit, but you've probably put it on already)
Check your turning torque with an in/lb. torque wrench and see if it's in specs, if not, tighten the nut in 15-30* increments(smaller as you get closer) until the proper turning torque is reached. I have done 4 gear swaps using this method in the past 6 months, all on my buddies cars, and none of us have had ANY problems what so ever. I have used this method on my personal cars over 6 times, same result. It works.
Edit: Sounds like you are at the auto hobby shop eh?
V
VelR5.0
25
SC
Nov 15, 2004
  • Nov 15, 2004
Well another fellow soldier I had a hard time trying to pull the old bearing out and pretty much destroyed the old shim, so not good here! Like you said to reuse the stock shim, my friend said the same thing but since the one that looked the same size was the .030 that's what I used. I'm thinking that the stock one maybe wasn't a .030 and now the pinion is in a little too much preventing the carrier to turn, being too tight. I'm going to look in the trash can right next where I was and take I look at the shim again. Do you think that lowering the shim to .028 will make a difference? Thanks in advance!!
BTW: Yep I got the Stang at the Auto Skills
V
VelR5.0
25
SC
Nov 15, 2004
  • Nov 15, 2004
H
HIGDON
241
Ft. Hood, TX
Nov 15, 2004
  • Nov 15, 2004
All you need is just a flat surface from the old shim to get a good measurement. I think my stock one was a .028. You can use the .012 and .016 shims out of the kit to get where you need to be. But just make sure you check the thickness of the old shim if possible, it's hard to see.002 with the naked eye. If you can't find the old shim, you have two options. Keep going smaller until you have a satisfactory gear mesh when checked with grease, or measure pinion depth to find the correct shim needed.
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
