  • 1994 - 1995 Specific Tech
Gear whine or ???
  • Thread starter Thread starter 94-302-vert
  • Start date Start date Apr 18, 2005
94-302-vert
1,947
NE CT
Apr 18, 2005
  • Apr 18, 2005
OK, I had FRPP 3.73 gears put in about 500 miles ago. On the highway at about 80+ mph (speedo is still off so this is 110+) I hear a whining. If i get off the gas it stops and comes back as soon as i feather the gas.
Now I thought it was that my rear suspension was causing something with the driveshaft before but i jsut got done rebuilding the rear end (new shocks, quads, LCA bushings (poly) and new UCA (free from a friend), and FMS C-springs.
Now I have not yet remove dthe D/S or changed the transmission mount yet. Any thoughts?
The gears are completely quiet below this speed.
Thanks,
Chris
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 18, 2005
  • Apr 18, 2005
If no noise when off throttle and at low speeds I would not be too concearned. My precision brang gearset 3.73's make a little noise on the highway..but just a wisper.
94-302-vert
1,947
NE CT
Apr 18, 2005
  • Apr 18, 2005
To me this is enough noise to keep me from maintaining a speed above 75/80 mph...
It is loud enough to be noticable and annoying.
Do you think my gears were not set up properly?
Will this eventually wear in and go away?
Thanks,
Chris
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 18, 2005
  • Apr 18, 2005
You need to find out. Take it to another shop, and have them check the pinion depth and backlash. Don't take it back to the same shop. They will just tell you that nothing is wrong because they will have to eat the cost of replacing the gears.
Scott
RIO5.0
6,892
N.H.
Apr 18, 2005
  • Apr 18, 2005
Somethings up...gears shouldn't whine...Gotta take your chances I guess or go back to the installer...which he prolly isn't going to like...taking it to another place is gonna cost you then your really gonna have to rub the other guys face in it...or once again eat it... sounds like a lose lose situation to me ???
I would think its only gonna get worse...I have only used FRPP gears tho...
good luck to ya...sucks to be you at the moment....
9
95conv5.0
184
  • Apr 19, 2005
u could have just got a set of gears that have been cut bad? u never know, check the pinion depth, if this is correct and the backlash is correct then dont worry about it
91LX_5L
1,943
British Columbia
Apr 19, 2005
  • Apr 19, 2005
thats your gears, dont worry unless it gets louder and worse
JJ95GTID
1,141
Phoenix, AZ
Apr 19, 2005
  • Apr 19, 2005
Here's another thought. Do you have the older FRPP 3.73 gears or the newer FRPP 3.73 gears. The newer style ones have different cut on the teeth for both strength and reduce gear noise. I have the older ones on mine (over 2 years now) and they do exactly what you described above. They did not get any louder and are completely quiet otherwise.
94-302-vert
1,947
NE CT
Apr 19, 2005
  • Apr 19, 2005
How can I tell if they are the newer or older gears? I didn't see them but I have the box they came in at home.
I have no problem with pulling the cover to check them out if I have to either.
Chris
JJ95GTID
1,141
Phoenix, AZ
Apr 19, 2005
#10
  • Apr 19, 2005
  • #10
part #M-4209-F373N = newer version
part #M-4209-F373 = older version
SWYZ721
208
Ann Arbor, MI
Apr 19, 2005
#11
  • Apr 19, 2005
  • #11
hahaha N=New!!!!11!!
Anways if the noise is only when above when on the throttle at 80+mph then I would say it isn't the 3.73 gear at all. Maybe your tranny.
94-302-vert
1,947
NE CT
Apr 19, 2005
#12
  • Apr 19, 2005
  • #12
I liked thinking it was the gears better... Good point though now the D/S is spinnig a buttleoad faster tahn it was... so the trans output is doing the same thing...
Other thoughts?
Chris
94-302-vert
1,947
NE CT
May 1, 2005
#13
  • May 1, 2005
  • #13
ANyone change the bearing on the output of the transmission? Is it something that makes it worth going into the whole trans to do? I see bearigns are like $8-$12...
Chris
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
